Hello,
I am having a constant struggle with getting my pool to clear in a timely manner. Every time I brush (about once a week) or if kids play in pool, it clouds instantly and remains for about 2 weeks. If I let my pool sit without touching or very light lap swimming, it will become sparking, crystal clear in about 10-14 days. This is my second year as a pool owner and have struggled with this the entire time. Even after stumbling across this site 2 years ago and learning proper chemistry, I am still having this issue (however, many other problems I was struggling with were resolved, so thank you TFP). The first year I used bleach and this year I converted to SWG. Here's some background info:
- Concrete/plaster 30+ years old, kidney shaped
- All original plumbing abandoned in place (the return ports appear to be stuffed with some sort of canvas material)
- Main drain does not operate
- I installed 2 return lines (above ground) on each end of the pool and then Y'd the lines when they entered the pool over the coping, using 4 Infustion "V-fittings" to help circulate lower levels of water since the main drain does not operate.
- Other details can be found in signature line
- I try to brush and vacuum (manual and Hayward Navigator) about once a week; however, I will sometimes let this go longer to allow the pool to clear
- I "deep clean" the sand filter at spring startup
- I SLAM'd at spring startup and have appeared to have no algae blooms so far
- I live in Northern Utah and I have a lot of foliage around the pool, fighting pollen and other small debris
- I keep a floating, solar blanket on the pool whenever not in use or cleaning
Recent Test Results:
- FC: 5.5
- CC: 0 (this has never increased so far this season)
- CYA: 60 (slowly working on increasing due to SWG conversion)
- CH: 220 (working on increasing to 300)
- TA: 110
- PH: 7.5
- Borate: 40 (Borates newly added for first time about a month ago)
- Salt: 3300
Could I have problem with the plaster just being so old and constantly deteriorating? There also seems to be two layers of paint that is slowly peeling as well. Let me know what other information I can provide and appreciate any thoughts or suggestions.
Derek
- FC: 5.5
- TA: 110
- PH: 7.5
- Salt: 3300
Derek
