Thread: So close... and yet so far away!
    IowanPool's Avatar
    May 2015
    Ankeny, IA
    24
    Angry So close... and yet so far away!
    I'm at the tail end of my first SLAM (I think). A week ago my pool was so cloudy that I couldn't see the bottom of the shallow end. I started the SLAM process on Wednesday (5/29). The water cleared st of the water, but I seem to have stalled out. I was dropping 10+ppm overnight. now I seem to be dropping 3-5ppm. I'm just curious if I'm missing something. I originally tested my CYA at 50 and have been using 20ppm as my goal. I had to buy a new bottle of r-0871 reagent because I ran out. I mostly need confirmation that I'm still on the right path:
    Current test (before I added chlorine):
    FC=15
    CC=.5 (probably less, but I was doing the .5 test)
    pH=7.2
    CYA=40
    TA=170
    CH=220
    SI=-0.1
    Any thoughts are appreciated!
    20x36' in-ground vinyl pool. 25.5K Gallons. Sta-Rite Sand Filter. Pentair Ultratemp Heat Pump. Pentair IntelliFlo variable speed pump. Tri-Chlor Feeder. Automatic Cover. Taylor K-2600 test kit. Pool owner since 2013.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: So close... and yet so far away!
    You are doing great,
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Aug 2014
    Northern IL
    4,615
    Assuming you are following slam recommendations (adding chlorine as often as possible to keep at shock level; brushing everywhere after making that FC high; vacuuming; SWG/chlorinator off; backwashing as needed; pump on 24/7; checking ladders, lights, and weirs for hidden spots; etc.) you are just fine.
    Hang in there!
    30,413
    You are doing fine but get that FC back up to 20 and keep it there. If you tested CYA at 50 ppm, you can probably assume it's still 50 so keep your FC at 20.
    Brush, run your filter 24/7, vacuum as often as you can, etc. You are close.
