Thread: Higher water level equal higher pump pressure?
    May 2015
    Hebron/CT
    10
    We've got a lot of rain in the past few days, and the water level has risen from about 1/3 the way up the skimmer openings to be above the skimmer openings. I noticed the pump psi has risen about 2-3 psi since the rain started.
    Does a higher water level in the pool equate to a small increase in pressure for the pump/filter?
    22x40 mountain lake design, 24,800 Gallon, vinyl IGP. Pentair Intellipro XF 3 HP variable speed pump, STA-RITE S7MD60 Modular DE Filter, Aqua Comfort Electric Heat Pump. TF-100 test kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Higher water level equal higher pump pressure?
    Welcome to TFP!
    No. What's likely going on is that your filter is catching some of the runoff - from the ground and out of the atmosphere - from the rain. Continue keeping an eye on your filter pressure and clean/backwash as needed.
