Results 1 to 10 of 10
Thread: Box of chemicals given to me
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    I had a box of chemicals given to me by a neighbor who tore down his pool last season. Included was this shock that he said "worked wonders" and "cleared up" his pool. He also said just pour it in and that's all you need. Of course I know that is not true but since I have about 15 pounds of this stuff is it possible that I could still use it?
    21'x52 AGP 11200 Gal
    TFPC Method
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Box of chemicals given to me
    It says copper. Stay away. Try to return it to a store that sells it for liquid shock/bleach or take it to a local household hazardous waste facilty.
    Isolated Spa - 345 Gallons
    May 2014
    Portage, Indiana
    127
    I was thinking the same thing with the copper. He did say it cost him about $100/box which I have 2. If I could get close to that back, that's all I would need for the whole season with TFPC method! When I saw 3 bottles of "water clarifier" and pH up down left and right along with a bunch of pucks I got a little worried that these magical bags didn't do what they claim.
    TFPC Method
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Yes, copper bad. Don't use it!
    Clarifier is useless as well, you won't need that following TFP methods.
    The PH up sounds useful, but be wary of the PH down if it's a powder. Powdered PH down is dry acid, sodium bisulfate. It works, but adds sulfates to your water (bad in the long run).
    The pucks can be useful for bringing up CYA if needed and if you go on vacation. Hopefully they don't contain copper either.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Just go down to the local pool store a little after they open and set the box out front with a sign that says "Free." Then run.
    Sell it on craigslist. Someone else who has used it and thought it "worked wonders" will probably snap it up for $50 - $75. Sure, you'll feel guilty about it, for a while. But it's not like you're the pool store that sold it in the first place.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    May 2014
    Portage, Indiana
    127
    Good idea! I'm sure someone will snatch it up on craigslist.
    TFPC Method
    May 2014
    Portage, Indiana
    127
    Haha!!!
    TFPC Method
    May 2014
    Portage, Indiana
    127
    Quote Originally Posted by jrs_diesel View Post
    Thanks for the info diesel
    TFPC Method
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    No problem
    J.R.
    20K IG gunnite pool
    Cartridge filter
