I was able to get my 20,000 gal pool clear using the method last year, and it was awesome. This time around I'm pretty sure I messed things up. I had no CYA to begin with so I shocked the pool with sodium dichlor about 10 lbs of it to raise cya. I started the process on 05/29 and the pool is still super murky and my numbers are way off, please help!!
Ph. ... Less than 7
TA..... 10 yes ten
Cya... 100 yes one hundred
Calcium hardness.... 70
FC.... 6
I don't know which I need to fix first to get the water balance right. Pool is definitely still pretty green.
Ph. ... Less than 7
TA..... 10 yes ten
FC.... 6
