Thread: Adding CYA question
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Adding CYA question
    I have noticed many saying they put the CYA in a sock (correctly) but then putting it in the skimmer. (Thinking incorrect) Has the recommendations changed, as when someone mentions it, no one is recommending they place it near the return, as in the past. Just curious....
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Adding CYA question
    Quote Originally Posted by PAGirl View Post
    Recommendation changed. Eithe or both is fine. If the pump is on all the time, there's as much water flowing through the skimmer as coming out the returns and it's a lot simpler to rig.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    From Richard's Inspirational Links thread: Recovering my old inspirational links
    Isolated Spa - 345 Gallons
    May 2015
    Savannah, GA
    62
    I actually took my cleaning pole secured it to hang over pool so it didn't fall in from weight of sock. Put the stabilizer in a sock, tied it off. Cut a slot in sock above knot slid hole in sock over the pole and hung it into my pool. Worked great!!!!!!
    24 ft round 52 in deep Evolution CLX 13,000 gal, hayward S180T sand filter & 1 hp Power-flo Matrix single spd, TFP method BBB, taylor K-2006 kit
    24 ft round 52 in Evolution CLX 13,000 gal, Hayward S180T pump sand filter & 1 hp Power-flo Matrix single spd, TFP method, Borates Added, Taylor K-2006 Test Kit (Rincon/Savannah,GA)
