Results 1 to 14 of 14
Thread: 50'x26' pool cover reel needed
    Jan 2013
    Southern CA
    50
    Hi, anybody have a suggestion for a reel that would work on a huge pool cover?
    Thanks Lisa - lots of old posts and suggestions!
    But anybody have experience with a reel that will accommodate a large, thick cover that will have to fold over first due to the irregular shape of my pool. I guess it would have to be one that sits up higher and can be moved out of the way.
    Here's a pic of the "fun" of the initial use - but it's a blob of a nightmare to take off and put back on.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 50'x26' pool cover reel needed
    Search in the search box for DIY pool cover reel and some stuff will pop up
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jan 2013
    Southern CA
    50
    Thanks Lisa- I couldn't upload the photo with a reply but it let me with the edit post.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome.
    Lisa
    Jul 2014
    Sacramento, CA
    241
    You might want to consider cutting the cover into 2-3 pieces -- I cut our 36x18 cover into 2, and it's pretty manageable without a reel. I pull it onto the deck about 3 feet, then pull it out 6 feet at a time accordion style. Then on the deck I fold it 3-4 feet at a time to end up with a reasonable sized square that I can either just slide out of the way and cover, or carry somewhere. Covering is reverse, unfold each section to length then pull on the corners to un-accordian it into the pool (keep the folds on the deck). The key is that a 10-15' long section will sort of lay itself out in the water as you pull from a side; a 35-50' section will never do that. Having gotten it down I can take it on or off myself in 3-4 minutes without going in or getting more than incidentally wet. A reel might be nice but I don't really have a good place for it to go.
    I tried making an ABS pipe roller as described in a thread here, but it didn't work well -- I think I need to trim the cover so it's an inch or two smaller than the pool (it goes up the sides a bit now, so it wouldn't roll on the pipe properly) and try again, but then I'd still be left with long rigid rolls to carry/put somewhere instead of a 4' square pile. I'd think 3 sections for your pool would make it much more manageable.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Jan 2013
    Southern CA
    50
    Thanks for your suggestion jm. Do the pieces get blown around out of place?- we have a lot of wind here. Our pool is exactly 50' long and it actually fits really nice. Just hate to cut it and then it starts shifting around- in our case, blown/drift onto the beach entry.
    Jul 2014
    Sacramento, CA
    241
    If the whole thing is trimmed to fit the shape of the pool, so that the edges are resting on water (protected by the coping/sides as opposed to flapping around on the deck), then it shouldn't blow around much. At the beach entry where the edges aren't as protected, perhaps a couple of bricks on the edges?
    Worst case, if you cut it and then decide to do a single reel, it should be possible to put grommets and tie the sections back together. YMMV, not responsible when you wake up with your house covered in bubble wrap, etc
    Jan 2013
    Southern CA
    50
    Oh- you're in CA too- I'd forget the cover if it didn't reduce evaporation by 95%(so it claims)- kids don't need to swim in 84' water anyway
    Might have to try cutting into pieces if reel search doesn't work out.
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by macdee View Post
    But *I* need 84+ degree water to swim, preferably 88 The cover makes a huge difference here in Sacramento -- our pool is at 86-87 degrees right now, while others I know without covers are below 80 (we haven't had a lot of really hot weather yet). While it gets hot here in the summer (average mid 90s, often 100+), it also cools off a lot at night (average low is in the high 50s even in July), and the cover helps the pool retain that heat overnight. Didn't get it until August last year, when the sun was already lower -- I might end up leaving it off some nights in late June/early July if the temp goes too high.
    Evaporation and chlorine usage reductions are just side benefits (and obviously if you are using the pool most days, the cover will be off and you'll get less of those benefits).
    I'd like to see the site have a "cover challenge" video series, where people show their various reels, pipe rollers, manual folding, etc techniques, and we can see how they work in practice. "TFP Olympics" It'd help people determine whether other solutions are really more or less hassle than what they're doing. Maybe I'll start by videoing next time I do mine.
    Jan 2013
    Southern CA
    50
    Oops
    Mar 2011
    441
    20X40 30,000 gallon gunite pool
    Jan 2013
    Southern CA
    50
    Thx Racket- will check out.
    May 2015 completed- 50'x30' beach entry(26'), two 50' swim lanes, diving board, jump rock, 4'-9.5' depth, 40K+gal salt water, Pentair,Screen logic 2 mobile for intellitouch., intellichlor and intellichem automated system. Jacuzzi JLX cuz we rarely used the last in ground spa :)
    Apr 2015
    East Wenatchee WA
    39
    I have to just say that this is the coolest pool ever!! !! Good luck with the cover issue. Some one will come up with a good idea I bet.
    15'x30' oval AGP. 12000 gal. 1 HP pentair pump. 19 inch sand filter.
    Auto vacuum thing that works through skimmer. Solar cover.
    OLD 400ish gallon Cal Spa hot tub with two new pumps (ouch)
    Jan 2013
    Southern CA
    50
    Thanks reeves! Been giving hubby all these suggestions - it's up to him now to decide which will work best for him and the kids-cuz I'm not lifting a finger
