Thread: Hayward Super Pump 1.5
    Mar 2015
    Mechanicsburg OH
    8
    How long would you say a pump should last? I replaced my pump 3 years ago and today and when I got home I discovered my pump stopped. I tested the outlet which also now seems not to work but when I plugged the pump into a working outlet it still did not work.
    Should I be running my pump 24/7? Could this be why my pumps only seem to last about 3 years?
    I have a 20x40 in ground pool.
    Thanks!!!!
    May 2015
    kingston springs, tn
    102
    Re: Hayward Super Pump 1.5
    My first Super Pump motor lasted 6 years and I am on my 4th year for the replacement. It seems very weird that the one outlet is dead and the pump won't run on another outlet. Did you have a recent lightning strike that could have damaged your equipment? What voltage are you running your pump, you mentioned changing outlets? With a pool that large I would think you would be running at 230v. If you update your signature with your equipment the people here in the know will have a better chance of helping you.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
