Thread: Crack in casing
    Jun 2015
    LA mesa
    1
    Crack in casing
    I have a crack in the cassing (attached is a photo of the part) and ive tried to fix it but when I turn it on, it pushes the adhesive I'm using to plug up the crack right off. Does anyone have any suggestions as I can't afford to replace amy thING right now.
    Thank you
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Crack in casing
    Where is the crack?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
