Thread: First TF test kit results
    May 2015
    Florida
    14
    Hello all,
    So my test kit arrived and after familiarizing myself with the instructions, I ran the test with only a little confusion and the results are as follows:
    TA 90
    CH 275
    FC 8
    CC 0
    pH 8.0
    Cya 57
    During the ch test, it turned a shade of pale purple and took another 2 drops before it turned what I would safely call blue.
    Aside from that, pretty straightforward. I turned the swg down a few days ago from 30% to 15% when oto basic fc test showed 5ppm consistently.
    Any feedback on the next steps is appreciated. I've done a bit of reading so I think I've got the idea, but then again, the last time I though I was taking the proper steps, I added a box of soda ash to the pool, haha.
    I'm hesitant on this one to go simply off of the pool calc, at least until I become a bit more familiar.
    Thanks again,
    -Loring
    10,000 Gal IG PebbleTec, travertine deck, Pentair IntelliChlor SWG, 1.5hp and 1hp pumps, easytouch 4 w/remote and wifi, waterfall/firebox combo
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: First TF test kit results
    Looks like you did it! Good job!
    Your PH needs to come down. Use Pool Math to see how much MA you need to use.
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Hi Havoc!
    Thats not too bad!
    The only things I see are
    1. Lower your pH just a bit. Maintain your pH somewhere from about 7.5 to 7.8. When it gets to 8 or above, it becomes risky for calcium scale.
    2. SInce you have a SWG, bump up your CYA to 70 if you want to. Maintain your FC as per the FC/CYA chart.
    Dont worry about TA to much. With a SWG, you want it a bit on the lower side. Using Muriatic Acid to lower pH will slowly bring that TA down just a bit more over time.
    If you find you are having to lower pH a lot, (2 or 3 times a week), then at that time, consider getting more active in lowering TA so as to slow down the pH rise.
    When doing the CH test, add regent 1 drop at a time until there is absolutely no more color change. Then subtract that last drop, and thats your CH.
    Whether its 250 or 275 isnt important, as long as you are in the mid 200's, then it's good.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Looking good! +1 on lowering PH.
    Here is the Pool School - Water Balance for SWGs.
    May 2015
    Florida
    14
    Awesome, thanks everyone. Its rained pretty heavily here, so I'm going to rerun the tests, one for further familiarization, and two just to see first hand the effect of the rain.
    I'll add based in the pool calculator at that point.
    Thanks again, all.
    -Loring
