Results 1 to 15 of 15
Thread: How do I move dropped off 500 pound pool to my backyard
    Jun 2015
    Tallahassee
    3
    Hi
    I would like to know of any ideas on how to move a new pool in box from front yard to back yard.
    I saw on the tracking that the pool weighs 509 pounds. They will only drop it off at the curb. It's 200 feet away from where I want to put it.
    The pool is a Sharkline Venture. I've never seen the box and I don't know what to expect.
    38,300
    Re: How do I move dropped off 500 pound pool to my backyard
    Welcome to TFP!
    Dollies and a bunch of people?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    A few people and a moving dolly with ratchet straps like they use to move refrigerators would be one idea.
    Another would be if you have a truck that you can pull into your back yard have them load it in your truck and then get some people to help you unload it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    Tallahassee
    3
    Wow!! I'm getting help! Thank you! I don't know where this thread is posted. I don't know how I found your answers. Obviously I am a newbie here. But, I think I will be hanging around. Thanks again.
    Do you know if the pool is on a pallet?
    Santa
    jjwalker's Avatar
    S. Louisiana
    198
    move from truck to truck bed? move from truck to tractor/front end loader? move from truck to gator or forklift?
    disassemble box in driveway, carry piece by piece? invite a bunch of unsuspecting friends over for pizza & beer and....surprise!
    18x36 vinyl / sport pool 5.5' deep / 1.5hp Tri-Star 2spd / Hayward c3030 325 sqft cartridge / ~15k gal / TF100
    Jun 2015
    Tallahassee
    3
    Good answers, Thank you
    Do you know if they come on a pallet?
    Santa
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Anything that heavy should be on a pallet. If it's not hard to get where it's going, a few guys could carry it. You could get a two wheel hand truck(dolly) and a ratchet strap to move it. The tractor idea would work. You could rent an off-road forklift for half a day. A truck would be the most cost effective. Just have them put it in the bed. If they drop it off at the curb, they have a lift gate, so no extra work for them to put it in a truck.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Is it concrete from the curb to close to the final resting place?
    Odds are, the truck has a pallet jack and a liftgate. The driver's not obligated to set it in the back yard, but he might be bribe-able.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    My best guess is that it will come in several boxes all tied down to a pallet. At least that is what I've seen when people here have installed an AG. Can't tell you what brand those two pools were, but that's what I saw.
    Casey's Avatar
    SW PA
    10,446
    I have a Sharkline Venture and it was not delivered on a pallet. We had ours put into outr truck from the delivery truck. It is heavy!
    Sep 2014
    Chelmsford, MA
    28
    We moved a heavy shed (~12x16(?) ) across the yard using some 4" pipes, jacked up the shed, put in the pipes and rolled it, when one pipe would fall out, you put it in the front. It worked way better than I thought it would. 500lbs should be way less than that, but if you have some 2-3" pipes lying around.....
    21,600 Gallon IG vinyl L shaped Pool
    Hayward DE3620 Pro-Grid DE Filter, Hayward 1HP super pump, AutoPilot SWG, 350,000BTU Hayward Heater
    TF-100 Test kit with options (salt strips, Borates, mixer)
    9/30/14 Dig Began....
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    We used our wood decking to move the hot tub to the back. slide and move the wood the front.
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Simply rent the right tool for the job. Call or visit websites of local tool rental shops looking for a multimover dolly. There are several like this available under the scope of material moving
    A regular appliance dolly with 6 inch rubber wheels will be a struggle over your lawn.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    Much to our surprise, our Intex 32 x 16 weighed about the same and was awkward to handle. Rent or borrow a "Dolly', you will save time and injury..
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    I like the friends over for pizza, beer and SURPRISE! idea! LOl
    A dolly will do the trick or maybe a STRONG wheel barrow.
    You can rent a LOWES truck for $19.99 for a couple of hours. If you can drive where it needs to go............
    When they brought my AG pool here they had a lift on the back and drove it to where it needed to be. They lowered it and put it right where I wanted it. I did give the guy $$ for being so nice.
    Kim
    Kim
