Results 1 to 12 of 12
Thread: TF-100 vs Taylor K-2006
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Just got my new TF-100 kit and Speed-Stir in mail today and ran all test with it. Then ran all test with my Taylor K-2006 kit. Everything is really close except for the CH.
    TF-100 read 275
    Taylor K-2006 read 220
    Pool store tells me 183
    Replastered a month ago and the pool sparkles like diamonds and clear as a bell.
    What should I believe?????
    All measures:
    FC- 3.0
    CC- 0.5
    PH- 7.6
    TA- 90
    CYA- 30
    Borate- 45
    CH- ughhh
    Temp 80 degrees
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Donldson's Avatar
    NW Ohio
    2,917
    Re: TF-100 vs Taylor K-2006
    Pool store results I wouldn't expect to be accurate, so scratch that off.
    How old is your k-2006? I am inclined to believe your TF-100 since the reagents are fresh, but there could be other variables at play here.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,524
    I agree with Donldson ... I mean the reagents for the 2 kits are identical, so the results should be the same unless they are old or there was some testing error.
    How much water did you use for the 2 CH tests? From the numbers, guessing 25ml for the K-2006 and 10ml for the TF-100
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Yep jblizzle you are correct I used 25ml mark on bottle with Taylor kit and 10ml mark on bottle with TF-100 kit. Maybe the reagent for the CH test is bad in the Taylor kit. I bought it a month ago but who knows how long its been sitting on shelf.
    Rick T.
    30,432
    I doubt the reagents are bad.
    When you do the 10 ml for the TF-100 the range is 1 drop or plus or minus 25 ppm. So the result could be 250.
    With the Taylor test, you chose to use the 25 ml sample so your resolution is plus or minus 10 ppm. So the result could be 230.
    The point is that CH roughly in the 200's is all that matters. If you have the time, test them both again using the same resolution....either 25 or 10 ml sample and see what you get.
    Remember, the endpoint of ANY color change test is that you add drops until the last drop makes absolutely no further difference in the color. Subtract that last drop and that is your CH.
    38,524
    I agree with Dave, it is in the mid 200s which is close enough; although I understand the curiosity.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Thank yall for the quick response. I will retest tomorrow using the 10ml and the 25ml with the new TF-100 reagent. Sure am glad I found this site
    Rick T.
    Aug 2014
    Northern IL
    4,615
    I gotta ask... If you already had the Taylor K2006, why did you invest in another kit?
    Also, make sure you are hold the reagent bottle perfectly vertically (upside down) when doing the drop tests. If you hold the bottle at an angle other than vertical, the drops will be smaller than they should be, skewing your results to the high side. And if you hold the bottle at a different angle each time you do the test, your results will be inconsistent.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Quote Originally Posted by MarianParoo View Post
    I figured my Taylor K-2006 might be old since it was cover in dust from pool store shelf. Then I decided to go with what most everyone else here uses.The TF-100 along with the Speed-Stir which is a way cool device.
    Rick T.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by TomBorg View Post
    Hey, never heard that before, handy information.
    Jan 2012
    'burbs of Augusta, Georgia
    7,370
    Quote Originally Posted by whataboy View Post
    I've never once read that anyone regretted getting that speed stir
