Thread: New to forum
    Jun 2015
    San diego
    8
    New to forum
    Hey guys I just wanted to introduce myself, my name is William and I live in San Diego ca. I just bought my second intex pool 18 x 52 and I'm pretty excited to put it together. I just have to do a little construction on my backyard such as break down some bricks and then try to level the pool. I'm kind of concerned about getting the pool perfectly level since there so many warning about it. I will be putting down some sand cause the concert is kind of jagged. I hope everything goes well. Thanks for having me here.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: New to forum
    Welcome to TFP William!
    It you read in the above ground pool forum and maybe even some in the construction forum you should be able to get some ideas.
    I do recommend purchasing a recomended test kit. I have the TF 100 linked in my signature and we also recommend the Taylor K 2006.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to forum
    Welcome to TFP!
    Jun 2014
    15,121
    Re: New to forum
    Hi William! Best of luck on the pool build. Post pics! We love pics.
