My pool is pretty cloudy with a slight algae look. I've had my chlorine pretty high but it hasn't made a difference. Did some tests and noticed that my Total Alkalinity was high. I need some face to face advice so I went to Lesley ( this is my first pool season). They said that I need to add 6 gallons of muriatic acid to lower TA. This sounded wrong, so I checked pool math and it says something totally different.
Plus I've add about 10lbs of cyanuric acid (used a sock in each skimmer) over 2 weeks ago and my cya is still low.
Test results from Lesley's print out
fac 5
tac 5
ch 250
cya 15
ta 200
ph 7.4
tds 100
pho 1000
I need some hand holding... or some basic knowledge of what to do and why.
fac 5
tac 5
ch 250
cya 15
ta 200
ph 7.4
tds 100
pho 1000
