Results 1 to 10 of 10
Thread: Leveling Pool! Please help!
    Jun 2015
    Shepherdsville, KY
    1
    We bought a 26' ultra frame intex pool. Spent 3 days leveling the ground, had 5 tons of sand delivered, leveled and compacted that. We used a laser level and thought we had it almost perfectly leveled. Started filling it with water and realized that one half of the pool was 6" higher than the other half. My husband dug out 6" from under the high legs and now the water is level, however it will still be deeper on one side due to the ground under the liner not being dug out 6". I was wondering if it will be ok to leave it like this for one summer or if we need to drain, take down and start over? Any help would be greatly appreciated! Thanks!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Leveling Pool! Please help!
    Safety first. That means drain and redo. I am sorry
    Kim
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Agree with Kim. Drain and fix. You DON'T want that much water escaping uncontrolled. It will cause property damage, and if anyone is in the way, it will damage them too!
    Casey's Avatar
    SW PA
    10,453
    I concur with the others. Let's do this right so it's safe and the pool looks good.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Find a friend with a transit, it's a great help! Or, see if you can rent one.
    May 2015
    Odense SŲ
    28
    I agree. 6" is quite a lot, even though the legs are level. I have an Intex UF as well and thats off by 2". Its jumping in my eyes every time I look at it, but it should last this season. The ground will be more level next season.
    Jun 2013
    Buffalo, NY
    80
    Quote Originally Posted by freezer20 View Post
    It's amazing how those little squares really catch your eye when the water is off even a little bit!
    A straight board and level is a great accessory in doing this. As PAGirl said, a transit can be a great tool as well.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Jun 2012
    MA
    347
    Quote Originally Posted by tcook0282 View Post
    I hate to sound harsh but you should be able to get the ground level within a couple of inches without even using a level. I can't imagine how you could be off by 6 inches while using a laser level. That makes no sense. I would question your competence on the whole pool set up. In order to be safe, you should hire someone to install the pool.
    May 2015
    Howey in the Hills, FL
    6
    I agree that you need to drain and start over. The best tools for leveling are a rake, a shovel, a compactor and a transit. Use the compactor to level as best you can by eye. Then, take the transit to each of your support blocks and it will show if you are level. If not, you can use the shovel to lower or add dirt, and the rake to smooth it out. Then, recompact and check your level with the transit again. You should be able to rent these from your local Home Depot or other tool rental store. Leveling is key to a safe pool. It is very time consuming and tedious, but the end result is worth it!
    Joanna M.
    New owner of 32x16x52" Intex Ultra Frame AG pool
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I was fortunate enough to have a friend with a Kubota AND a transit, lol. He let me borrow the transit until completion. I learned how to use the transit today, it's an electronic laser (?) one. Pretty neat stuff. We are off about an inch and a half, after putting down the modified 2A rock. Still have more raking to do. Hope things are going well for you!
