Thread: Can a 48" pool be made deeper by using taller liner and digging in?
    May 2015
    Colorado Springs
    94
    We most likely will get a uses 15'x48" doughboy/lomart pool this week end. It needs a new liner. I would love to make it deeper as I like aqua aerobics and every inch counts. It there a possibility of digging down 6" and having a deeper liner. I have seen variable depth liners but those have a slant and it would be nice to have a flat bottom. There is a good chance this pool is oddly a 15' which might limit my liner choices.
    Used pool 1995 Lomart 18'x48" just installed 7/16/2015, Hayward Power Flo Matrix 1 HP 2 speed pump, 16" Rx Clear Radiant sand filter ( used pea gravel and zeolite) foam wall, polystyrene bottom, liner 25 gauge overlap, TF-100 test kit. Son training for 2018 Paralympics, Hoping for solar heater of some sort. Good chance Labrador will be in pool. Colorado Prairie, 6000 ft elevation high mountain desert, clay soil
    Mar 2014
    south central PA
    112
    Re: Can a 48" pool be made deeper by using taller liner and digging in?
    Google Expandable/overlap liners. They can be used for a deeper pool.
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Casey's Avatar
    SW PA
    10,423
    Quote Originally Posted by pigeon View Post
    Agreed. Good luck!
    Mar 2014
    south central PA
    112
    yeah, I'm pretty sure someone on this forum just posted a bunch of pictures about how to install an overlap liner .
    Check out Casey's post about installing an overlap liner. It will show you exactly how to do it. Digging 6" deeper would be fine, and the shape of your bottom isn't really a concern (ours is done as a "traditional" deep-end, but scooped is very common).
    Casey's Avatar
    SW PA
    10,423
    I just installed that liner today in my brother's pool.
