Thread: Cloudy water High FC
    Jun 2015
    allegan/MI
    1
    Pool is cloudy only can see 2 feet down in shallow end. Opened for 3 weeks.
    Readings
    cya 50
    tc 10.6
    fc 8.9
    cc .7
    ph 7.3
    ta 99
    th 282
    copper .3
    have been fighting this for 3 weeks. New sand. Filter seems to be working perfectly. no air in the lines.
    have just added algicide again yesterday. pool stores keep telling me everything is balanced. now there is white stuff when I filter. Flocced this morning stopped filter at 8:30 it is now 3:30 and there is no change.
    30,000
    20 by 40
    Hayward s200 sandfilter
    38,235
    Re: Cloudy water High FC
    Welcome to TFP!!!
    First, I assume you need to invest in one of the Recommended Test Kits and stop going to the pool store which is clearly not helping you.
    Then you will need to follow the ShockLevelAndMAINTAIN Process to clear up the pool.
    We do not recommend the use of algaecides or flocs or clarifiers or any other pool store potions.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
