Results 1 to 14 of 14
Thread: Issue with jets in steps
    May 2015
    TN
    312
    I noticed today that my right hand jet (facing pool steps from entry point) is spurting air in busts of every few seconds. I have the adjustable jets. When I turned the knob towards the other jet it got worse. I am needing help determining what my problem is. The jets in the actual wall of the pool are not doing the same thing. It is just the one jet. Of course the other jet had air in it when I adjusted it, but it quit soon afterwards. My pressure gauge is normal. Help...
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    May 2015
    TN
    312
    Re: Issue with jets in steps
    I just went back out and turned it (the jet itself) until it completely shut off to divert to the other jet. THe other jet done exactly as the right side one.
    38,284
    pictures?
    If they are jets on a bench, then they may be designed to pull in air, like spa jets.
    May 2015
    TN
    312
    Can you see pic?
    I don't think I can post anymore pics due to storage. The steps has a dial at the top in the middle. This is the jet that is not forming bubbles. The other is constant bubbles now.
    38,284
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    So there is a dial to adjust the amount of air coming out?
    May 2015
    TN
    312
    Yes, there is a dial. And turning it makes it worse. I can also hear the noise of water going down a drain when I turn it completely one way. You know that sound you can hear from an uncapped pipe as water rushes down the drain. I am also curious as to why it is just now doing bubbles. Up until now I could hear air in that jet, but no bubbles until today
    May 2015
    TN
    312
    Please, disregard the dirty steps ^^^^
    38,284
    I am pretty sure those are meant to be like therapy jets that suck air in by the passing water in a venturi. The dial on the top should open and close the ability for the air to enter.
    If they are not all getting air, then your flow rate might be too low. And if you never got air before, then the flow rate must have been lower to these jets. Can you isolate these so that you control how much water the bench jets get?
    May 2015
    TN
    312
    I have no clue ... Not keen on all that and we didn't install pool to see everything go in. Would pics of my pump and piping help?
    All in all, if I just leave it alone, it shouldn't be a problem, right?
    38,284
    Post up pictures of your plumbing ... if you do not understand them, then you should learn what everything does.
    All the bubbles will do is aerate and drive the pH up some.
    May 2015
    TN
    312
    38,284
    So ... what do the valves do? Right now you have both suction lines open (left valve) {presumably, the floor and skimmer or a cleaner line and skimmer} and both return lines open (right valve) {guessing normal wall returns one way and the bench jets the other way}
    Turn the return valve one way or the other and see what changes.
    May 2015
    TN
    312
    I do know that if I turn the lever (one on left) to the right (from 6oclock to 3 oclock) it shuts off both skimmers! lol
    38,284
    So that likely means only the floor (the left pipe) was running in that case.
    Turn the one on the right, you can not hurt anything.
