UPDATE!!! :queen:
Because I finally discovered TFP last season and all that I have learned in PoolSchool and all the help from the forum.... I just had the
sweetest pool opening EVER!!!
In a mere 5 days and a dozen gallons of bleach... SLAM complete!!! I cut 30 days and 100 gallons of bleach off last year"s opening (my first time)!! So, I add in my salt & begin bringing CYA up to target. All that's left to do is dial in my SWG
This teacher is sooo thrilled to actually spend her summertime off in her beautiful Trouble Free Pool :sunny:
So, I'm floating around thinking that life can't get any better & I noticed a couple of specks of something on the bottom:grrrr: Yes, I'm becoming OCD about my pool! So, I get out & hook up the vac & go to town. I vac to waste, then backwash to clear in the spy glass, then rinse to clear & turn the filter back on ready to dive back into my PERFECT pool, but horror of all horrors!!! sand & all kinds of **** is shooting out from the returns back into my pool!!!
So, I go back to TFP and read up to make sure I am vacuuming correctly and fill the pool back up (I used a lot of water vacuuming, backwashing & rinsing) and start over. I vacuumed to waste until it was clean again, opened the pump basket to clean it & it had quite a bit of sand in the bottom!! (I've never seen that before) cleaned it out, backwashed & rinsed again twice, just to make sure, turned it back to filter & stuff came out again!!! Ugggggh! Also, the pump basket while running has a lot of air bubbles churning in it, the top of the sand filter (around the connection between the multiport valve & top of sand filter) is leaking water & the pump pressure is is up to 24psi & is normally 15psi! I tried more backwashing but the pressure stays high!
Okay, so I'm thinking it's the fitting under the multiport valve that's leaking & hopefully I need a gasket or something and I don't have a major problem. All help is always welcome
HELP!! Thanks
