Results 1 to 18 of 18
Thread: help with 0 CYA and 0 TC
    May 2013
    austin/texas
    140
    went to pool store to check my water and here is what I got.
    FC: 0
    CH: 120
    CYA: 0
    TA: 30
    PH: 6
    I read some posts that suggested shocking the pool first but no algae is showing and I also checked FC last night and it was around 2, do I need to shock first before addressing TA/PH issues?
    Should I address the PH first or the TA?
    Also do I use dry stabilizer to bring up CA or liquid one for faster results?
    Last edited by antoniosp; 06-02-2015 at 01:38 PM. Reason: added question about shocking also
    34x15, 17K Fiberglass In-Ground Leisure Morroccan SWG, 1 1/2HP 2 speed SuperfFlo pump, Pentair Intellichlor SWG, Pentair Clean & Clear 320 cartridge filter, Pentair EasyTouch 8 panel, 4 returns, 1 skimmer, Installed August 2013, Fiberstar 3-color LEDs, AquaBot AWD robot cleaner, Pentair Easy Touch 8 Wireless remote.
    38,475
    Re: help with 0 CYA and 0 TC
    You should get one of the Recommended Test Kits and stop having your water tested at the store which is proven over and over again to not be worth what you paid for it.
    May 2013
    austin/texas
    140
    yeah I got the Taylor K-2006C3 kit but have never gotten in the habit of checking my CA or TA on it, just the PH and FC and then relying on store for rest of measurements. (lesson learned I will start checking all with my kit instead)
    38,475
    So post up YOUR test results and then we can figure out what needs to be done.
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    Jun 2014
    15,221
    Antoniosp, as noted, without tests from a reliable test kit we cannot speculate on your water. That's how bad store testing is. We've all been there. Refer to the TF-100 link below if you would like us to help and for YOU to take charge of your pool. The test kit pays for itself and you'll almost never need to go to a pool store again. Also, check-out the other links below in my signature. Extremely valuable info.
    I see you have the Taylor 2006C. Very good. Post some numbers for us!
    May 2013
    austin/texas
    140
    ok so i tested with my kit and the numbers are pretty much the same, except i couldn't verify the CYA (ran out of CYA reagant and just re-ordered more) but I went to a separate store and for same reading on the CYA. so feel ok that these number are valid. having said that what should I tackle first since?
    Jun 2014
    15,221
    Well, we certainly would rather have YOUR CYA results from your own kit, but nonetheless, you are saying 0 FC and 0 CYA. Those need to be corrected right away to avoid algae blooms. You can use the Poolmath Calculator and Recommended Levels links in my signature to calculate how much bleach and stabilizer to add. Just enter your pool volume at the top of the calculator, then enter the "Now" and "Target" numbers based on the Recommended Levels chart. The calculator will tell you exactly what and how much to put in your pool. It's crazy hot in our TX area today, so without CYA your FC (bleach) is going to burn-off right away. Same goes for figuring out the TA and PH on the calculator. If you have questions about the calculator or how to proceed, let us know.
    Jun 2014
    15,221
    By my quick calculator check, I show you needing the following:
    FC - 141 oz if 6% bleach
    CYA - 91 oz of granule stabilizer or 235 ox or liquid stabilizer
    TA - 160 oz of baking soda
    PH - 150 oz of soda ash
    SWG experts may have more advice, but definitely get that bleach in there right away.
    May 2013
    austin/texas
    140
    i actually started super chlorinate mode couple of hours ago and FC shows at 2 right now even though sun is blazing. I was looking at calculator just not sure if I should address the PH or CYA situation first?
    38,475
    What does the water look like?
    Get the pH into the 7s.
    Then add at least 30ppm of CYA into a sock and start it dissolving.
    Then get some FC in the water using bleach.
    Leave the SWG off until you get things dialed in.
    May 2013
    austin/texas
    140
    yeah I turned SWG off. water looks good and clear with no signs of algae i was even swimming this sunday and checked FC and was in the 3s. lesson learned check all chemistry more often.
    Jun 2014
    15,221
    That's good. But keep a close eye on that FC - never let it drop below 3. Without much CYA (right now), FC will disappear fast. It will take a few days for the CYA to kick-in. Here near San Antonio, I have a sock (CYA) soaking because my CYA got low and my FC was dropping quick each day, and I know it's hot in your neighborhood as well.
    May 2013
    austin/texas
    140
    yeah the 1/2 gallon shock helped FC is at 3.5 now. also PH is at 7 so I just added 1 gallon of liquid stabilizer also.
    May 2013
    austin/texas
    140
    numbers started looking better
    FC: 4
    CH: 80
    CYA: 30
    TA: 80
    PH: 8
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    PH 8 is not good. Did Poolmath say to add 1 gallon of acid? If yes, then adjust the number of gallons you use for the calculation. If not, then use Poolmath to tell you how much to add. It is important to maintain PH between 7.2 and 7.8.
    May 2013
    austin/texas
    140
    yeah PH of 8 is high maybe I added tad too much of Soda Ash to raise my PH from 6. I added 64oz of stabilizer to increase my CYA which lowers the PH so waiting for that to take effect before I add muratic to lower the PH
    May 2013
    austin/texas
    140
    just retested
    FC: 6.5
    CH: 80
    CYA: 35
    TA: 70
    PH: 7.6
    I got the sock filled with dry stabilizer to increase my CYA and pump running and SWG off. Will check later this evening. making progress...
    May 2013
    austin/texas
    140
    almost there...still got stabilizer being diluted via socks in the skimmer to keep raising CYA until it gets in range.
    FC: 4.5
    CH: 40
    CYA: 50
    TA: 75
    PH: 7.2
