Results 1 to 14 of 14
Thread: copper blocks for Intex question
    May 2012
    Las Vegas, NV
    92
    I keep seeing post about removing it. Is this necessary for an above intex pool?
    I have the Krystal Clear Saltwater Model 7110/8110. I've been getting low salt but when I do the test kit I get about 4000 for salt reading.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    38,514
    Re: copper blocks for Intex question
    If you do not want the copper added to the pool and potentially get staining and green hair, then at a minimum you should disconnect the copper wires.
    Low salt warnings when the salt level seems to be fine often point to a dirty cell or a failing cell. How old is the SWG?
    May 2012
    Las Vegas, NV
    92
    its about 3-4 weeks. so that old. I notice if I turn it off and back on it will work for a few days and then the low salt message comes back.
    K-2006 TEST KIT
    38,514
    That is odd. Might want to contact them about warranty coverage. How did you verify the salt level?
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    May 2012
    Las Vegas, NV
    92
    I used taylor test kit K-1766 CHLORIDE SALT WATER , added my info.
    Is intex pretty good at replacements. I'm assuming they will send me a replacement and i'll have to return the damaged or other way around?
    K-2006 TEST KIT
    38,514
    I have no idea about the warranty methods. But, clearly it is not working correctly.
    May 2012
    Las Vegas, NV
    92
    Thanks for you help. I will look into this.
    K-2006 TEST KIT
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    If your unit is less than 2 years old, they will replace it for free. I've never had them ask me to send the old one back.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2012
    Las Vegas, NV
    92
    Quote Originally Posted by jeffchap View Post
    Just called they said that they will send me the TITANIUM ELECTRODE part and that it was a common issue.
    K-2006 TEST KIT
    Jun 2014
    Holbrook, NY 11741
    1
    Did they ask for a receipt?
    May 2012
    Las Vegas, NV
    92
    yes. i will admit I couldn't find my receipt so I did the unthinkable. I saved a receipt from amazon, and modified it with all the intex details. it got approved.
    K-2006 TEST KIT
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,554
    Duly reported to the authorities...
    Pentair IC40 SWG
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    May 2012
    Las Vegas, NV
    92
    honestly they should know its a legit device by the serial number, not sure why they make you jump through hoops. who saves all receipts lesson learned.
    K-2006 TEST KIT
