Results 1 to 13 of 13
Thread: Rookie in A ball here
    Jun 2015
    Butler, PA
    7
    First thing first. I am reading every word of Pool School.....now my story
    Pool Specs
    24x52 above ground some name thing that holds water
    1hp Maxi pump
    Heyward EC40 filter (with bolts) so its old.
    So here i am "living the dream" My fiance and I just bought our first house. Much to my Disliking we bought a house with a pool....(happy wife happy life....). we were initially told HEY! the liner is good but a little old. I later find out it was 15 years old, leaked water like shower head. So i embarked on that journey which ended up being pretty easy. now i go to the pool store without doing research (I am a avid post guy on a VW forum) so i should have done my homework before going in. I thought i would get an easy answer and swim. I WAS WRONG I GOT POOLSTORED!!!!!.
    they sold me PRISTINE BLUE!
    The chemicals have been in my pool for 5 days now....so not too long at all.
    I should have on my door as i type at work a nice test kit so once i get that i will post some test results.
    my biggest thing is this....I DO NOT want to refill some water in my pool. DID I change my mind soon enough i can get the Copper out or neutralized out of the water?
    HELP......I am a car guy not a pool guy....apparently i am now though.
    Jun 2014
    15,059
    Re: Rookie in A ball here
    Which test kit did you order?
    By the way .. Welcome to TFP! We'll help you figure this out.
    38,271
    Welcome to TFP!!!
    Well the copper is in the water now, just do not add any more. You could try the Cu-lator product which seems to have shown some effectiveness at removing copper from the water.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jun 2015
    Butler, PA
    7
    i got the 2006 one...full name is missing from my brain at the moment. I have not and do not and will not add any more of that stuff in my pool.
    absolutely i will!
    Jun 2015
    Butler, PA
    7
    also another random fact. Sunday it decided to Monsoon and filled the pool with about an inch or two of rain water. i don't know if that will be affect anything or not
    First home Pool NOOB
    24x52 Above ground pool / Old Heyward EC40 Earth / 1 HP Maxi Pump / New liner / It has water in it
    38,271
    If the pool did not overflow, then the rain did not do much ... 2" in a 48" pool is only a 4% change in water. So your CH, CYA will have dropped by 4%.
    Jun 2015
    Butler, PA
    7
    it did not overflow it did get up to the top of the skimmer opening.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    why you gotta steal my math
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Butler, PA
    7
    Quicker to the punch
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    welcome to the forum, post some numbers up once you unpack that kit and everyone will let you know where to start
    Also, VW CC APR stage 1 260hp
    Jun 2015
    Butler, PA
    7
    Cowboy. Will do.
    04 R32 fully shaved bay show car PVW December this year
    Jun 2015
    Butler, PA
    7
    Metal test didn't show up.
    Ph 6.8
    FC 3
    Alk 0
    CA 0
    38,271
    The number of people post a 0 TA today is crazy.
    If true, your pH must be down in the 4s
    You need to start using PoolMath and raising your pH until 30 mintues later you get a reading in the 7s. Then recheck the TA as it may need to be adjusted.
    Then you will need to add CYA to protect the FC from the sun.
