Results 1 to 8 of 8
Thread: Rebar Rust???
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Rebar Rust???
    My pool is brand new and has had water in it for about 3 weeks now. Two days ago this stain presented itself. Each morning it looks like it has an orange layer on it and then when I flake it off with a brush it's orange/black. Pictures attached. I asked the PB to look at it but wanted to get your thoughts on it first. Do you think this is rebar bleeding through?
    -25,000 gal. freeform gunite, smooth quartz finish w/ spa
    -2 hp Jandy Pro Series Stealth; Jandy Pro Series Cartridge Filter (CV340)
    -Jandy Pro Series AquaPure Chlorinator; Jandy Pro Series JXi Heater
    -Zodiac MX8 cleaner; Taylor K-2005 DPD Complete Chlorine Kit
    Jun 2012
    western NY
    1,561
    Re: Rebar Rust???
    Someone else posted something similar to this a couple weeks ago. It turned out to be a small piece of metal that somehow got into the plaster. The builder was able to get it out and repair it.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Re: Rebar Rust???
    Quote Originally Posted by danpik View Post
    It sounds like this is what I should hope for since everything I have read about rebar rust requires the repair to go into the gunite and remove the rusted rebar.
    Dec 2014
    Riverside California
    482
    Re: Rebar Rust???
    I had this problem on a pool a number of years ago. It turned out to be one of the wires that attach one rebar to another was not tied back properly and was sticking out too close to the surface of the plaster. The PB knocked the plaster off from around the wire, cut the wire then patched the plaster. Sucks that you would have to drain the pool to do this. I would get the PB to not only fix this, but to pay for the water bill and new start up chemicals also.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Re: Rebar Rust???
    Hate to hear that. I figured it would require some additional work and draining down the pool. Hopefully they only have to drain it down to the area (3" below tile line). I intend on having the PB cover all expenses.
    Thanks for helping with your reply!
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Re: Rebar Rust???
    I forgot to ask...have you had any issues with it after the repair?
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Re: Rebar Rust???
    The PB just came out and looked at the spot. He used some sandpaper to remove the spot and said to keep an eye on it. Not 15 minutes after he left the rust stain came back. So....it looks like it's probably a rebar bleed. They have to drain the pool below the stain and remove it. The good thing is the spot is only about 3" below the tile line so minimal water loss. The will be covering the water and any chems needed to re-balance the pool.
    Dec 2014
    482
    Re: Rebar Rust???
    Quote Originally Posted by tackettaj View Post
    I moved from the house that had the repair about 10 years after the repair, and it was still good when I left. The trick is to get the wire or whatever is causing the rust well below the surface.
