Thread: skimbi and vacuum hose
    May 2015
    covington
    9
    I purchased the skimbi for my intex pool, when I hook up my vacuum to this do I have to fill the vacuum hose with water, and what do I set my pump to waste or filter or what? thanks in advance
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: skimbi and vacuum hose
    Filter. Unless you want to drain some water out of the pool.
    May 2015
    covington
    9
    Do I fill the hose with water?
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by mrsshokrok1 View Post
    Yes. And it has to sit a little below the surface or the pump will suck air, lose prime, and overheat. I'd just connect the fittings to the pump inlet, attach the skimbi to the wall and adjust the height so it gets flooded with water, and then jam the hose on. Takes longer to type than to do, most likely.
    May 2015
    covington
    9
    Thank you
