Thread: Ph creeping up
    Jun 2008
    Marana, AZ
    347
    Ph creeping up
    Hello,
    Generally I have no problems with Ph, so this issue surprised me. I chlorinate using Kim-Tec liquid chlorine usually, or Up & Up brand bleach if I only get over to Target and not Lowe's. I also occasionally use Kim-tec brand tri-chlor if my CYA needs to be raised. I just started with using tricolor to raise my CYA again on Saturday. Since I only occasionally have to get my Ph down, I use Kim-tec brand Ph minus, as muriatic acid tends to sit around a long time before I get it all used used up - generally I will not go through a 2 gallon case in a season.
    Anyway, I noticed my Ph was starting to creep. I measured 7.8 yesterday (actually more between 7.6 and 7.8), so I put in about 1/3 cup of Ph minus. Today I checked my Ph again, and it was 8.0!
    I didn't add any other chemicals other than the Ph minus, and the tricolor my little floating dolphin tricolor dispenser is putting out. What would cause my Ph to go UP when I put in Ph DOWN?
    Numbers from test yesterday (except chlorine and Ph, which was today):
    TC = 3
    CC = <.5 (This was yesterday; the test turned just barely pink, and went away with one drop. It was so light, I'm pretty sure if I could have used less than a drop that would have worked.)
    FC = > 2.5
    Ph = 8
    T/A = 120
    CH = 260
    CYA = 30
    Temp = 82
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Ph creeping up
    Did you add any high alkalinity fill water recently? That could do it.
    A bunch of vigorous aeration, like a gaggle of kids having splash fights, could also drive pH up.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Ph creeping up
    Your FC or to low for your CYA
    PH is high as you know. I would use MA to bring it down to 7.2 and let it aerate back up to 7.8
    It rises quickly because your TA is high.
    Adding MA will also help reduce your TA
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
