Results 1 to 19 of 19
Thread: Pool Basketball Goal question
    Jan 2015
    Tuttle/Oklahoma
    147
    I have had my eye on the S.R. Smith Salt Friendly Basketball goal but our PB said that he has had better luck just inserting a 4 sleeve into the concrete decking and using a regular basketball goal, only using part of the pole instead of the entire thing. He said that you can get a better goal with a break away rim for half the cost. Anyone heard of this before or have any thoughts on it?
    My Pool Build Thread: 21 x 40 Freeform Gunite Pool, 12" Tanning Ledge, 3.5 shallow graduating to 4.5, 8.5 deep end, 4' Waterfall which doubles as a diving ledge with 6' x 4' Grotto underneath, 670 sq. ft., 106 Linear ft., Rock Salted Concrete Deck, Pentair 520 Filter, Intelli flow 3 HP VS pump, (4) Color LED lights, Intelli-Chlor SWG, Hot Springs Vanguard Hot Tub with ACE and BT Sound System, ODK, TF100
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    Re: Pool Basketball Goal question
    I'm interested on suggestions on this as well.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My neighbors have one similar to this. They like that it's not another hole in the concrete decking and they can move it out of the way easily or put in different areas of the pool if they want without much fuss.
    Amazon.com : Lifetime 1306 Pool Side Height-Adjustable Portable Basketball System with 44-Inch Clear Acrylic Backboard : Lifetime Poolside Basketball : Sports Outdoors
    Isolated Spa - 345 Gallons
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Or if you would like more stability, ability to move it and no rust (at the expense of, well, money and perhaps looks) visit our build thread in my signature for our solution.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    With the pool side I worry about it falling on someone when they dunk. Is there enough weight so that doesnt happen. Safety is my #1 concern!
    Aug 2014
    NJ
    435
    We just installed the SR Smith and it looks nice
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Jul 2014
    Pittsburg, KS
    31
    My Uncle filled an old car tire with concrete an a partial basketball pole. He had an inexpensive plastic back board and regulation goal. The whole thing set on his deck with the goal basically even with the side of this AGP. To my knowledge it never fell into the pool, and we had many a dunk contests on it!
    Intex UltraFrame 14ft x 48in deep, 3,700 Gallon, Intex 14-Inch Krystal Clear 1,600 gph Sand Filter Pump, Taylor K-2006
    Quote Originally Posted by MGood View Post
    Than don't let them dunk? I too have the one that was linked above and our family and friends have enjoyed it since buying it....and it's easily moved so we can put in the volleyball net as well....
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Ours is about 500 lbs when full and has a breakaway backboard setup. Tension needs to be properly adjusted for the breakaway to function correctly which is easy. Tipping it should not be an issue.
    As for the no-dunking policy, my salute to those able to enforce it. I'm a lesser being. It's almost like an innate desire hard wired in males to dunk (and maybe some females but I haven't witnessed that yet).
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    I would love to say no dunk but with three boys do we really think no one is gonna dunk? I'm the kind of person who always thinks what if and not willing to take a chance. My question was if there was enough weight so it wouldn't be able to fall in on someone.
    Jun 2014
    15,012
    Really a personal choice Sooner. Literally dozes of choices out there for both stationary and portable basketball hoops. I never liked the small cheesy portable models at some of the local stores, but I found a heavy-duty portable one that suits our needs (viewable below in the "My pool" link towards the end of the pics). For those that anticipate some aggressive "Final Four" matches in their pool, perhaps a regulation rig is more in order. Drilling/mounting is the nature of the beast for those as well, but can be done nicely as others have already mentioned. When you decide, maybe post a pic for us to see and others to learn?
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    To be official, the goal must be 10' from the top of the water.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Do you walk on water?
    Mine can be 6' from the deck and if it's in 3 1/2' of water that's about right. The hoop is regulation. It's a commercial quality hoop used at at least one university per the reviews.
    Jan 2015
    Phoenix, AZ
    638
    the rust is a good point, especially with a salt water pool like we r getting. i called SR smith and they said their rims rn't breakaway and u can't hang on them. they get anchored into the rebar. the woman said 12" back but i read the instructions on line and it says to place it 18" back from pool (water's edge i imagine). i need to decide, too, by today since they were to install coping tomorrow and have a 3" sleeve planned for them to install. i'm wondering if that's even enough room for a regular basketball hoop pole.
    40' x 12' IG shotcrete (3 1/2' 5, 4'), Hayward variable spd pumpSP3400VSP, Paramount PV3 in-floor, venturi skimmer, 14,400 glns, Hayward Turbo salt cell T Cell-15, UV, Hayward DE filter, model DE4820, 2 Hayward Color Logic 320 LED color lights, Hayward P4 w puck. 2" line to in-floor valve (46'), deck mount canister parascoping fountain, leaf canister, Marbella, pebble. new build 6-24-15
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    I could be completely wrong on this since I'm new to the pool thing. What I was thinking of having the hole (socket??) put where I wanted it so if I decided down the road I wanted to do it I could. I would only be able to do a single pole though and would have to be happy with that for a hoop if we decided to do it. I got a great idea on this forum to do sockets for umbrellAs, so no matter what the hole would get used. Good luck!��
    Jan 2015
    Tuttle/Oklahoma
    147
    Quote Originally Posted by outdoorsgal View Post
    I think the size will depend on the goal you buy. Most of the ones that I am considering are 4" poles I believe. My concern is more along the lines of if it will damage my decking. I think that dunking is inevitable (I will probably be the first one to throw one down) but if I catch someone hanging on the rim.... With the PVC sleeve we could just pull it out and cap it when not in use. Is damaging the decking much of a concern?
    Jan 2015
    Phoenix, AZ
    638
    went to Leslies pool supply and they actually sell a heavy duty pole that fits in a 3" sleeve and they sell a fiberglass backboard that isn't made for pools. $250. i think that's the route i'm going. pb said it'll be a deep hole and strong. the guy said the rim at Leslies breaks down if someone pulls on the rim, which I think is a plus.
    and, yep, i agree, u can always use the hole for something!
    Jan 2015
    Tuttle/Oklahoma
    147
    I will have to stop by Leslies and take a look.
    I was thinking something like this http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER (trashing the base and half the pole). When we are not using it just pull it out of the ground and put a cap on the hole. I'm guessing this is similar to Leslies solution.
    Jan 2015
    Phoenix, AZ
    638
    do u think the pole will be easy enough to cut through? for me, we'd have to purchase a saw made for that and so then we'd prob be even on the cost but then the basketball net wouldn't be adjustable if u went this way. not sure how necessary that is unless u have kids, i guess. the pole at leslies is $55 at one store and $100 at another. big 5 had a backboard like the one u posted, i think lifetime, too, for $100 if u ask them to give it to u at a sales price. $100 plus $55 for the pole at leslies is not a bad deal. but then, do most backboards fit the pole? i'm almost thinking of just getting the whole set up at leslies cuz it's easy and should work together. i also called spaldings and they said the one for sale at leslies is made for putting on a garage or a roof and she'd need to see a pic of the poles to see if it'd work on the pole.
