Thread: silicone for spa?
    silicone for spa?
    i am in the process of replacing my jets on my hot tub. where can i find silicone that is suitable for permenant underwater? i haven't found any that is suitable for underwater.
    18' 52" deep laguna agp with pentair 1 1/2 hp pump and 22" filter, intex swg
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: silicone for spa?
    Sealing jets and so on isn't technically "underwater". You should be fine with any quality kitchen/bath or marine silicone. I usually use GE or 3M depending on what's on the shelf.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    You could also try aquarium adhesive.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    and what is the proper way to seal it? i got a plastic gasket that comes with the jets and i dont know which side to put the gasket on. does it on the inside of the tub or the back side of it?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The gasket goes on the inboard side. Be careful not to tighten the fitting too much or the gasket will start to squeeze itself out.
