Thread: Pool light gasket problems -How to tighten
    Jun 2015
    Spring, Tx
    1
    I was wondering if anyone had any problems with the type of light? The kind that requires a wire to tighten the gasket to the housing? I don't know how tight i should tighten the screw. Mine looks a little different than most I've seen on forums and i continuously get water into my lens. I applied plumber's putty to the back of the wiring harness and I'm hoping that'll stop any water from ending through the back of the housing. 20150531_132436.jpg
    Last edited by BoDarville; 06-02-2015 at 10:25 AM. Reason: Moveed from old thread & Removed reference to old thread
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Pool light gasket problems -How to tighten
    I just took my light out for the first time yesterday and my screw was tightened all the way up.
