Thread: New User Needs Advice On Using Pool Math
    Jun 2015
    Phenix City, AL
    7
    Trying to sneak up on water balance in newly filled in ground 24,000 gallon vinyl pool. Trying out the Pool Math. Not sure what to do with the TA and PH adjustment it is giving me. Don't want to overshoot for sure. Current conditions:
    FC-5
    CC-0
    TA-70
    PH-7
    CYA-45
    Salt-3200
    Hardness-0
    So far I have added salt and 10# Sodium Bicarbonate to get me here.
    I have always been told to get TA where it needs to be before you mess with PH.
    It is telling me to add 169 oz of baking soda AND 63 oz of soda ash simultaneously.
    My question is does the calculator take into consideration that I am adding something for TA that will affect PH and vice versa at the same time???
    Should I get the TA where it needs to be completely before I try to adjust PH?
    If anyone has advice or suggestions it would be appreciated!
    24,000 gallon in ground, SWG, outdoor, vinyl, sand filter 3/4hp pump.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: New User Needs Advice On Using Pool Math
    I would leave them both alone. PH will rise with aeration. You can point the return jet up to help aerate. Your TA is fine at 70. If TA is too high it will cause your PH to rise quickly and then you will have to lower it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You have 0.0 hardness? That is extremely unusual. What are you using to raise pH? If you enter that on the bottom of the Pool Math page, it will tell you the effect on your TA. Focus on the pH, not on TA. In most cases this is the correct action.
    Essential Links:
    Jun 2015
    Phenix City, AL
    7
    OK. I haven't adjusted PH at all yet. I was always told to work on TA with Sodium Bicarbonate and leave PH alone unless it didn't come in range after adjusting TA.
    I also use a Taylor K2006.
    I also checked the hardness before I added the salt.
    It may not be 0 anymore.
    38,248
    TA is fine like the others said.
    Use a little borax or soda ash / washing soda / sodium carbonate if you want to bump the pH up slightly.
    CH measures calcium.
    Salt adds sodium.
    They will not change each others results.
