Thread: Outdoor solar shower
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Hi
    Have anybody here build a outdoor solar shower ? Have seen that one DIY solar shower but cannot find the black ABS pipe anywhere near me. So I was thinking of using one of the black 55 gallons drums food graded. But not sure if I connect hose to it there will be enough pressure to push the water upwards toward the shower head. Any ideas?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Outdoor solar shower
    Flex poly piping is sold in huge rolls in the irrigation/sprinkler section at Lowes.
    Years ago when I worked at a Boy Scout camp, we set up a temporary field shower and tried solar heat by laying coils of 1 poly tubing out in the sun. The first few showerers got scalded, the next few were okay, and everyone else got ice water straight from the well. A barrel will work only if it's sealed air tight and the outlet is at the high point. Open the shower and let all the air bleed out and let it heat up. If the hose can push water up that high by itself, the barrel is just a wide spot so it will work.
    Personally, what's wrong with finding black garden hose? It's already got fittings on it and if things don't work out the way you hope, you at least have plenty of hose to use for other stuff.
    Pysiek's Avatar
    Apr 2012
    419
    Basically it takes a lot of space and does not look as clean as other things
    Sep 2014
    Fort Lauderdale, FL
    146
    The ones you can purchase allow you to mix the hot water with tap water for temperature control. That's worth a couple hundred bucks instead of getting scalded at first, at least IMO...
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by jeffbrig View Post
    I spoke to my wife. And since we have two young kids we decided to buy one.
    Feb 2011
    Petaluma, Ca
    665
    The one in the first post is similar to one I built, it in my pool thread. Works pretty good if the day temps hit 80 deg, you will get at least 10 min of warm water.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
