Hi guys, looking to change out the light in our pool.
We have a fixture similar to this one (about $250 online for the entire fixture and lamp)
And I am curious, do you need to change the entire fixture and wiring out, or can you just replace the light bulb with something like this?
Feit Electric 400R/FL 400-Watt R40 120-Volt Pool/Spa Flood Reflector - Halogen Bulbs - Amazon.com
I looked at the fixture this morning and it does appear that there is a way to remove the lens to get inside the fixture but wasn't sure how "sealed" from the factory they were and if you had to replace the whole unit when the lamp goes out.
![7844100_24502.jpg](http://edc.poolsupplyworld.com/wimages/product_image/7844100_24502.jpg?600x600)
