Thread: new liner
    Jun 2015
    ontario/canada
    6
    new liner
    I recently had a tree fall in my inground vinyl pool and I now require a new liner and some pool bottom repairs.
    The pool bottom has been fixed and the newliner is on its way bit I am concerned that the rain water going under the old liner will cause problems, they had to cut out several sections of liner to repair the bottom leaving it exposed.
    Should I do anything?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: new liner
    I would see about having them come out right before putting in the liner to see if any damage was done.
    Kim
    Jun 2015
    ontario/canada
    6
    Re: new liner
    Quote Originally Posted by kimkats View Post
    Kim
    The repairs are done, I am worried that the stagnant water under the old liner will cause mold to form or soften the pool bed, not sure if that is possible but it seems quite porous.
    FOXXX 27x41 lagoon, vinyl
    Aug 2014
    Northern IL
    4,615
    Re: new liner
    When I had a pool builder replace my liner, they spent quite a bit of time sterilizing everything with liquid chlorine. They also evened out the bed and strengthened any weak areas. Your guys should do the same. I would share your concerns with them in a non-confrontational manner.
