Thread: depth of sand under frame pool
    Jul 2008
    smithfield VA
    32
    we are going to be installing a 26 foot frame pool (intex/proseries type).
    My husband insists that we are supposed to have 6-8 inches of sand under it!
    I'm reading and everything I see says 2-3 inches.
    the site was excavated for a 30' metal wall pool so there is a 32' diameter hole in the ground (heaven help me), but due to various reasons we ditched the metal wall idea and went with the frame type.
    Please settle this question as I need to price and order sand soon!
    thanks so much
    proseries Metal frame, 26 x 52 -purchased, installing soon
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: depth of sand under frame pool
    You said you already excavated. I am assuming the excavation is leveled? If so then I would add sand to reach the top of the leveled part. Wet it down, confirm it is level. You won't want to bury a soft sided pool unless it is rated too.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
