Thread: Add acid after rain or wait?
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    In discovered that aeration from rain causes my pH to rise. With the amount of rain we have been getting I find I'm added acid pretty often. Is this normal or should I just wait a few days after the rain to see if the pH settles it self down?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Re: Add acid after rain or wait?
    I will say that I have not seen my PH go down on its own. I have to use MA. I do a test after a big rain and add MA as needed.
    Of course I almost always have to drain water after such a big rain and I do wait until my water level is where I want ti before I do anything else to the water.
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Z7,
    TA is the buffer which controls the rate of pH change. It may be that you need to lower your pH a bit.
    We have been diluged with rain here in Texas as well and I myself, have not experienced any pH problems.
    If you would post up some test results, we may be able to make a suggestion about it.
    Divin Dave,
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    we just had rain all day sat and sunday, but i had the solar cover on so that prevented any aeration i guess. just for fun i collected a cup of rain water for testing and got
    FC: 0
    CH: 0
    TA: 0
    CYA: 0 (didnt really test that )
    pH: 7.2
    i knew it would have 0 FC and 0 CYA, but i didnt know what to expect from CH and TA, but they were both 0, i was surprised.
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Today my FC was lower than expected. It was a 3.5-4 normally it's a solid 4-4.5. TA was a little low at a 80-90. CH is falling too at a 200. pH always seams to be high. Never really can get it at a solid 7.5 and stay there. Today it was 7.8. Its always at a 7.6-7.8.
    So I added
    42oz of 12oz Bleach
    32oz of Baking Soda
    10oz of 36% HCl
    And 3oz of CYA
    Didn't test CYA cause I'm out of solution but I'm thinking that since the pH was on the high end, chlorine dropping fast and TA falling that all this rain and me draining is lowering my concentration. I didn't think it rained yesterday though(worked last night)
    Today it was
    FC barley a 4
    CC 0
    TA 90
    CH 200
    PH 7.8ish hate that pH is up to the users discretion
    CYA N/A
    Temp 85
    Time Tested 1315
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Quote Originally Posted by poolnoob.ca View Post
    FC: 0
    CH: 0
    TA: 0
    pH: 7.2
    Uh, your chlorine is low in your rainwater, it is going to turn green! I would have expected CH and TA to be 0 because it is freshly condensed water that hasn't been sitting around absorbing minerals from the ground.
    Quote Originally Posted by Z7What View Post
    So I added
    42oz of 12oz Bleach
    32oz of Baking Soda
    10oz of 36% HCl
    And 3oz of CYA
    Today it was
    FC barley a 4
    CC 0
    TA 90
    CH 200
    CYA N/A
    Temp 85
    Time Tested 1315
    With rising PH it is OK to let your TA gradually fall to a lower level to see if it helps to hold your PH a little steadier. Keep adding acid to lower you PH to 7.2 every time it gets to 7.6-7.8 and that will help lower your TA.
