Thread: From browser to forum member
    Jun 2015
    Jackson NJ
    4
    I'm a city boy who could barely swim...bought a house with a beautiful pool in the suburbs. I would like to spend a little less and enjoy the pool a bit more while keeping my babies safe. Google led me here over the past 3 years to answer questions but mostly ended up following the pool store's costly advice. Seems like I have to relearn all aspect of pool care each spring (went to pool school last year)
    34000 Gal IG Vinyl
    Hayward DE ec-75
    Hayward Super Pump 2 HP 1.5 Impeller
    Taylor kit-Aqua Blue Chlorine Generator
    250K BTU electric heater-Blue Diamond Pool Cleaner
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Re: From browser to forum member
    Welcome to the forum!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    You're right there on the edge - jump on in!
    Which Taylor test kit do you have? The right test kit makes all the difference.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
