Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Platform for kids??
    FunFinder's Avatar
    May 2015
    Cajun country, Louisiana
    115
    Platform for kids??
    Any reason I shouldn't try to use this as a platform for my little one to stand on in the pool? Thinking of putting weight in the boxes for stability and possibly covering the top with a plastic textured sheet called "poly wall" I found at HD. The shelf is rated for 200 lbs per shelf and is very sturdy. My son is tiny, but swims like a fish, so I'm not worried about him falling off. He just needs a place to have his feet touch, so he can rest and play. Do you think this will work?
    Intex Ultra 9'x18' AG, 2800 Gph .75hp pump, 77# sand filter, Intex ECO SWG, Hayward wide mouth skimmer, KK Lil Shark vacuum, Intex magnetic light, TF-100 w/ SpeedStir
    Casey's Avatar
    SW PA
    10,457
    Re: Platform for kids??
    I would get a bathmat n put under the corners to protect the liner n go for it. Hardest part for you would be getting enough weight the weigh it down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    If it's all plastic, it should work. It also looks like as he grows you can saw the legs off.
    Definitely cushion the floor. And be scrupulous about maintaining FC, because there's a lot of hiding places for algae there. If it was me, I'd make it a point to remove the thing once a week and give it a good scrubbing just for that reason.
    FunFinder's Avatar
    May 2015
    115
    Casey and Richard, thanks for the replies. I was worried it would leech something toxic when combined with pool water. I put one shelf in my bathtub and had no problem keeping it down, although I'm not sure if that translates to pool the same. I'll be so happy if it works. I like simple. I've seen some pretty complicated platforms built from pvc and trex like panels. Thanks for the tip on cushioning the bottom and regular cleaning. Will do! I'll let everyone know if it works.
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    We are actually making ours with pvc pipe and plastic we bought from grainger. I teach swim lessons so would be using it as a platform for the kids to sit.
    Where did you get yours?
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    FunFinder's Avatar
    May 2015
    115
    Quote Originally Posted by lovestoswim View Post
    It's just a utility shelving unit from HD for $50. Snaps together in 2 min. Comes with 5 shelves, so I will have two platforms. Tonight I added an umbrella holder in one corner with the extra legs- I think it will be good- I'll let you know if I ever get the pool up!
    Casey's Avatar
    SW PA
    10,457
    Take pics too. I have a 2 year old granddaughter and I'll probably be making her something like this soon enough.
    FunFinder's Avatar
    May 2015
    115
    UPDATE! It's working great! I glued shelf liner to the bottom with some left over pvc glue to keep it from rubbing on the bottom of the pool. It turned out very sturdy. Adults sit and my kids jump off. I put half a cinder block in each box. Very easily moved for cleaning and I placed it directly in the path of the jet water flow to make sure it gets good circulation. The poly wall top is not slippery and I used zip ties to secure it on. Also, using the left over legs for an umbrella holder works great too. I'll have to get a pic of that this weekend. Thinking I might try to make my own steps now!
    Richard320's Avatar
    Jan 2010
    19,051
    Thanks for the update!
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Pretty cool idea ... Well done
    I might have to do this as well ...
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    FunFinder's Avatar
    May 2015
    115
    Thanks. As an alternative to my shelf build, if you don't mind a dark color in your pool, I think this Corfu table I just purchased should be perfect and not need any modification... Might want to check it out. Completely made of plastic and very sturdy. Snaps together and stays together. Got it on amazon for $50.
    Jul 2012
    Chicago, IL
    358
    My kids have been in swim lessons this off season and my wife just asked the other day if there would be some way to get a platform similar to that they use in swim lessons in our pool. I said, let me ask the question on TFP, and lo and behold, here is my answer! Thanks so much for including pictures as well!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    FunFinder's Avatar
    May 2015
    115
    Glad to be helpful!
    FunFinder's Avatar
    May 2015
    115
    Another update: the PVC glue did not hold the shelf liner I glued to the bottom of the platform to protect the liner of the pool. Any suggestions for a better adhesive?? Still loving the platform though!
    Jul 2012
    Chicago, IL
    358
    Good to know. I actually purchased the materials (exact same, HD shelves and that big piece of polly wall!) yesterday and plan on putting it together tomorrow to have for what is probably our first 3 day stretch of sunshine and no rain of the year. My little girls are very excited.
    This is just a guess for an adhesive, but what about the stuff that comes with patching kits that can be applied under water??
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Quote Originally Posted by FunFinder View Post
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    FunFinder's Avatar
    May 2015
    115
    Thanks for the tips on adhesive, esp the picture! Now I know what I'm looking for at the store. Paul's, post a pic when you get done with it in the pool.
    Jul 2012
    Chicago, IL
    358
    Fun Finder,
    Did you use the feet? They only provide 4 of course so curious if you used them on one and not the other or neither?
    FunFinder's Avatar
    May 2015
    115
    No, I did not use the feet, as I was worried about putting dents in my foam under the liner. After we got the first one in the pool, I decided we did not need a second one- we have a small pool.
  20. Back To Top    #20
    Jul 2012
    Chicago, IL
    358
    Without the feet the legs seem to poke through the bottom so don't you have the same concern then? Or this is what you used the shelf liner to address? Did you use the shelf liner in just the four corners?
