Thread: Testing water to see what the chlorine level is
    Jun 2015
    toronto
    33
    Hi there- maybe a dumb question but what test strips do I need to see if my salt cell is generating salt according to what has been set on the control panel. I.e control panel is set to 60% and I want to see if the Chlorine level in the water is really 60%. There seems to be an abundance of test strips out there but I am not sure which is the one I need.
    Thank you!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Testing water to see what the chlorine level is
    Hi David,
    welp, it seems you probably misunderstand how the salt cell works.
    60% means it is only producing chlorine for 60% of the time it's on (while the pump is running).
    Your chlorine is still measured in ppm as usual. (we here at TFP dont trust test strips though, as they are notoriously inaccurate).
    FC should be kept at recommended levels as per the FC/CYA chart.
    Pool School - Chlorine / CYA Chart
    To set up the SWG to meet the recommended levels, is a bit of trial and error process and testing the water daily over possibly a couple of weeks or so.
    You can turn down the % on teh SWG and increase the pump run time
    Or you can turn up the % and lower the pump run time
    either way will still produce x amount of chlorine which meets the recommended level.
    so you just have to play around with it to get it just right.
    Divin Dave,
    Scuba_Steve's Avatar
    May 2015
    Pooler, GA
    311
    Yes, the SWG is converting salt to chlorine. Salt test strips are used to make sure you have added the appropriate amount of salt to your pool so the SWG can operate correctly.
    6425g Intex Ultraframe 18'x48" AG
    Stock 1500gph cartridge filter / Intex SWG CG-28669 with E.C.O.
    Install date: 5/26/2015
    TF-100
    Helpful Links
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    If you want to test you salt level I highly recommend the Taylor salt test kit linked in my signature.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Donldson's Avatar
    NW Ohio
    2,892
    Sounds like you also need to get your hands on a Taylor k-2006 if you haven't already. That is the kit you need to properly test your Free Chlorine to make sure you have your SWG % dialed in properly.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
