Thread: AquaTrol run time?
    May 2015
    Pittsburgh/Pennsylvania
    27
    AquaTrol run time?
    Does anyone have an AquaTrol and run their filter pump 24/7? How would this work? Would the aquatrol then be running 24/7 as well? Can you run them seperate? Just a little confused before I buy one.
    21' 54" round AGP, Hayward 1hp 2 speed pump, Hayward Aqua Trol HP SWG, Hayward 150 sq ft cartridge filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: AquaTrol run time?
    You can run the pump 24/7, but that's really overkill. If you do that, you would just adjust the swg output lower so it makes the correct amount of chlorine for your pool. I run my pump 6 hrs a day with my swg set at 80-85%.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
