Results 1 to 9 of 9
Thread: Oh where oh where did my CYA go?
    Jul 2014
    Cedar Park, TX
    114
    I actually know the answer to the question. We have had a little bit of rain in Texas and that led to lots of pumping water off. The pool looks great. I was noticing that my chlorine consumption was a bit higher than usual. I ran a CYA test today after I saw a 4 ppm loss. My CYA was down around 20 - might have been a little lower I ran out of tube. The dot was pretty much gone. Because I am traveling at the end of the week I decided to use liquid stabilizer to jump it up right quick. Seems like most folks have trouble with too much and mine just got up and went. The pool store guys tried to set me up with all kinds of stuff when I went in to buy the stabilizer. They actually had a heavy rain pack all ready for folks to pick up. I got out of there as fast as I could.
    12600 gallons, 24 foot round above ground
    Hayward Sand filter, Hayward Powerflo 1.5 hp Single Speed pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Oh where oh where did my CYA go?
    If you're like most folks....................it went down stream lately!
    Jun 2014
    15,298
    That's hilarious. It is a great feeling to walk into, and quickly out of, those pool stores. Oh, and my CYA also dropped like crazy the past few weeks. I have a sock handing near my skimmer right now.
    Jul 2014
    Peoria, IL
    389
    Did the heavy rain pack include algaecide??
    That is hilarious.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Apr 2015
    Round Rock, TX
    25
    I have a similar problem. I brought mine down slowly from 100+ last year(with 3 partial drains) to about 45 this spring. After all the rain and overflow, it's down to 25. I'm also going away shortly, so using some pucks during the vacation should bring it back up. If I would have known, I could have saved a lot of precious water.
    12,350 gallon IG plaster pool
    Hayward cartridge Swimclear 4025 filter
    Hayward Super II 2.5 Hp pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by woodyp
    That's what happened to mine. Lost around 10-15 ppm CYA this month. Added some back yesterday. Amazingly, I was able to keep up the FC throughout "rainmageddon". It rained 24 out of 31 days in May and most of those rains were downpours. Didn't have to worry about much FC being lost to sunlight, that's for sure.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by graler View Post
    .... They actually had a heavy rain pack all ready for folks to pick up.....
    Pool store owner
    Feb 2015
    Austin, TX
    50
    Yep. I have never had a pool and I was in the process of getting the thing under control by slamming when all the rain started falling in central TX. I had measured my cya to be 90 (I guess from years if pucks from the previous owners) but I was reluctant to drain given our water situation. After the Memorial Day weekend downpours I thought I probably should check again and it was below 20 ... Ups. I guess I have been slamming at way too high levels for a little while. I hope I haven't damaged anything ... But I also got a sock in the skimmer now
    IG plaster pools built in 1985 (?): 16k(?) gallons lap pool (62'x8') connected by a spillover to 17k(?) gallons squarish pool (22.5'x18'). DE filters Pentair NS-48(x2), polaris 280 (non-functioning). Inline chlorinator [removed!] -> Circupool Si60 SWCG [Newly self installed March 2016!]. Recently acquired dolphin nautilus+ [Summer 2015]. Still figuring out what else I have and how things work.
    May 2015
    Clarksville
    146
    I just set up my first pool thus year, and buy my chemicals from Walmart. I'm afraid to go into a pool store. I don't want somebody trying to sell me a bunch of stuff I don't need. If you know the basic stuff you need just go with that and don't let ppl sell you a bunch of junk.
    vinyl soft sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
