Thread: Overflow?
    May 2009
    Trenton NJ
    497
    Overflow?
    This maybe a stupid question for someone who has had a pool for 10 years but what do most people do when it rains so much your inground pool overflows? I drain water to waste but do some pools have a passive way of doing that?
    Like some kind of overflow drain that does it automatically?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Overflow?
    Some pools are plumbed with an overflow pipe above the waterline. When the water gets to high it flows into the overflow pipe and is directed away from the pool. I don't know if that is something you could retro fit.
    Love TFP? Become a
    TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Overflow?
    Yup. Exactly.
    Exactly like Zea says. Its a pipe in the side of the pool that drains water out of it to ...wherever.
    Some have valves on them, some don't.
    Some are connected to sewer, others out to maybe the edge of the yard or in the pasture if you live in the country.
    Its one of those optional things that any decent PB should either offer as an option or even include it as a basic item for any pool.
    Quote Originally Posted by ethany View Post
    Divin Dave,
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Re: Overflow?
    My pool has a one inch pvc overflow pipe that connects to the top of the skimmer. Whenever the water gets high enough, it just drains. The 1 inch pvc line runs under my pool deck and into the woods behind our house.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Jun 2012
    western NY
    1,561
    Re: Overflow?
    I just backwash the heck out of my filter.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2009
    Trenton NJ
    497
    Re: Overflow?
    you know I wonder now. The basket in the skimmer is at an angle so there is a 1/4" gap there. I thought it was them just screw up setting the connection between the pool n basket. I put some epoxy to fill the gap. Could that be the overflow or just a F- up on their part.
