Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 110
Thread: Owner Builder North Texas
    May 2015
    keller
    129
    Attached are our initial plans. Dropped off at utility company today to get the dig test complete then off to city for permitting. Please chime in with thoughts and questions!
    - Approximately 17K gallons
    - 4'-6'
    - 3 3' sheer descents on back raised wall
    - 3 bubblers on tanning ledge
    - plaster - unsure at this point
    - pentail equipment
    - Robot cleaner
    - 2 LED lights
    - 2 skimmers
    - decking - travertine
    If there is a better way to attach this attachment please chime in
    Attached Files Attached Files
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: Owner Builder North Texas
    Welcome!
    Take and share a pic of your yard where the pool will be going so we can picture it.
    Do your plans talk about the size of the filter at all? Of course the bigger the better with that!
    I love the last thing on your list! That is a must have!
    Kim
    May 2015
    keller
    129
    Thanks! I will go with a large filter. Still deciding on equipment.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Cool design to maximize your space. We have 3 benches in our pool and 4 would be better. Good for kids to play/rest on and good for adults to sit and sip. Maybe one on each end and one in the middle zig. I am a big fan of my 3hp VS pump, it has done everything I've ever needed, waterfall, filter, skimmer, drain, solar. We like our rocksalt color hardener concrete deck. It is zero maintenance and great after 3 years. We like our pebble finish, but quartz seems like a good upgrade option between plaster and pebble. Lots of happy quartz and pebble owners here. Pics in build thread in sig.
    May 2015
    keller
    129
    Quote Originally Posted by pooldv View Post
    Good to hear about the 3hp vs pump. I am/was concerned that would be overkill. Which specific Pentair do you have?
    May 2015
    keller
    129
    Pics of backyard
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Welcome to TFP. Looks like I live 1.4 miles north of you (as the crow flies).
    I saw a post on here yesterday where someone had 3 scuppers that had different heights above the pool surface and was getting low flow from the highest one, and had no valve to adjust the flow between the scuppers. Not sure if that's a consideration for you.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jul 2012
    Tallahassee, FL
    30,525
    Is the orange paint pool or pool and deck? I like how it uses every inch of your back yard!
    Please check on your "rules" on having the windows so close to the pool. Some places require special windows. Just a heads up in case that is your case.
    I like it being right there. You can look out and watch your lab swim! LOL
    Get lots of doggy towels!
    Kim
    May 2015
    keller
    129
    Quote Originally Posted by epro05 View Post
    Small world! Thanks for the tip about scuppers - I will be sure to address with my designer.
    Quote Originally Posted by kimkats View Post
    Kim
    The orange is the pool - not deck. I too prefer to make the most of backyard rather than a free form with our lot. Thanks for the input!
    DFW, TX
    24,497
    Quote Originally Posted by DFWguy View Post
    It is definitely overkill. Pump goes up to 3450 rpm and I never run it above 2500, usually 1950 rpm or less. But, the smaller pump wasn't enough cheaper when I built my pool. They have the superflo now which might be enough cheaper and a good alternative.
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Pentair IntelliFlo Variable Speed Pump 011018 | Pentair 011018 | Sunplay.com[/QUOTE]
    May 2015
    keller
    129
    It has begun. I'm having to post all of this from my phone because we cut the att line today. The excavators did am amazing job. Steel and plumbing tomorrow
    Owner Builder; Under construction, 17K Gallons SWG IG Geometric; 31X20'; 600sf; 104ft perim; depth 4'-6'. Sun-shelf; bubblers; sheer descents; Dolphin M400; Pentair Intelliflo XF; Clean and Clear 520; Easytouch 8; IC40; 2 color LEDs; TF-100, K-1766, SpeedStir
    May 2015
    keller
    129
    edited
    Jul 2012
    Tallahassee, FL
    30,525
    "What have you done to my backyard???" Says the doggy! LOL
    Time for the MUD then that fun!
    Kim
    Jun 2013
    Fort Worth, TX
    68
    Glad the excavator worked out for you guys.
    Fort Worth, TX
    Inground gunite 32'x20' freeform salt pool Coping: Flagstone Finish: Undecided Decking: undecided Equipment: All Hayward. 3hp VS pump, largest cartrifge filter, 400k heater Cleaner: undecided robot for sure.
    Start Date: Whenever it stops raining!
    May 2015
    keller
    129
    Me too. What a testimony for this community. Thanks again!
    May 2015
    keller
    129
    These guys are busting it out. It's hot. I feel bad watching them
    Jul 2012
    Tallahassee, FL
    30,525
    Now is the time you measure everything. Is it as deep as you wanted? Are the shelfs wide, deep enough? Do you like the slope?
    Kim
    May 2015
    keller
    129
    The steel crew just finished. Much bigger job than they anticipated. I used a LOT of steel. They said I used TOO MUCH steel. I will post more pics tomorrow.
    Jul 2012
    Tallahassee, FL
    30,525
    Is there really such a thing as too much steel?? NOPE! Too little yes! Too much NO! LOL
    Kim
  20. Back To Top    #20
    May 2015
    keller
    129
    edited
