Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Getting no flow with new aqua pure 1400
    May 2015
    new orleans, la
    16
    Changed out sensor about four months ago. Changed cell one week ago. Aqua pure 1400. Now getting intermittent no flow. I have read that there is a "reset" button? I see a reset button on the panel. Is this it? Or, is there a reset button on the small adapter piece that connects the flow sensor to the panel? Thanks.
    Oceansol's Avatar
    May 2015
    Oceanside, California
    14
    Re: Getting no flow with new aqua pure 1400
    There is a small circuit board into which plugs the sensor cable. On the edge of that board is a tiny white button that says "CAL" nearby. Next to the button is a tiny LED that should be steady ON. If not, push and hold the white button for 5 seconds, and the LED should illuminate steady green ON. That re-calibrates the sensor. Hopefully this will fix your problem.
    18,000 gallon, in-ground plaster, salt water chlorine generation, all Jandy equipment, solar water heat, paper filters, in sunny southern California
    Jun 2011
    Long Beach, CA
    2,790
    Turn off the system and unplug the little board and then reinstall it. Turn on the system, wait for about 5 minutes, and then hold the little white button for 5 seconds. This will calibrate the sensor.
    Do you have a VS or 2-speed pump? You need to make sure that you do have enough flow.
    May 2015
    new orleans, la
    16
    I assume the button that says "salinity" is the one to push? By 2 speed pump you mean "on and off"? If so, yes it does not have a variable speed. I also don't see a tiny green LED.
    Oceansol's Avatar
    May 2015
    14
    Quote Originally Posted by nanunanu View Post
    No, you have to open up the panel to access the circuit boards. The button is on the small board that the sensor plugs into. It's tiny, on the edge of the board. The LED is also tiny and looks like a resistor, but is actually an LED. The fact that you don't see it shows it's not on. I didn't shut my system off, I just pushed the button down and held it for 5 seconds. Then the light came on steady. You can't miss it when its lit. The Jandy tech support guy was on the phone with me when I did this. Good luck!
    May 2015
    new orleans, la
    16
    Ok. Possibly I have a different circuit board. I opened the panel. Underneath where the sensor plugs into the circuit board is a small white button. Pencil eraser size. Says salinity over it. Is this it?
    Oceansol's Avatar
    May 2015
    14
    No, it says "CAL", but can't remember exactly where. The button itself is smaller than a pencil eraser... more like a pencil lead. It's nearby. The LED is next to it as well. I wish I had photos.
    Jun 2011
    Long Beach, CA
    2,790
    It sounds like you have a single speed pump. A 2-speed pump has two different speeds that it can run, high or low.
    The calibration button is on the small adapter board that you plugged the sensor into and then plugged that board into the main board when you installed the new sensor.
    May 2015
    new orleans, la
    16
    I did not use the small adapter board. From my instructions that came with the sensor, "attention installer, this part has changed, you do not need the flow adapter board."
    Jun 2011
    Long Beach, CA
    2,790
    If you are 100% sure you have the proper amount of flow then my guess is that the sensor is starting to fail.
    May 2015
    new orleans, la
    16
    Really appreciate your help ping. I changed out the sensor a few months back. I have a new spare sensor that came with the new cell that I installed. As of this morning "flow". Next time I see a "no flow" I'll change out the sensor. Seems like a sensor would last more than a couple of months but who knows.
    The newest trisensor doesn't use the adaptor board. It does have a selection for program A or B. Check the included instructions to make sure you have selected the right program.
    How old is your unit?
    Support the site
    May 2015
    new orleans, la
    16
    Sensor is about four months old. Cell is about one week. System was put in in 2007. I changed out the sensor today so in fact, as of now, sensor is brand new. Program A is the proper program and is running. Fingers crossed.
    Is your software revision 02 11 0A 10?
    Support the site
    May 2015
    new orleans, la
    16
    Yes, its the first one that pops up. Program A.
    May 2015
    new orleans, la
    16
    Now I have changed out the sensor, brand new sensor, worked fine for a while, now getting no flow again. Help.
    Did you verify the software revision by pressing A B and C simultaneously?
    Support the site
    May 2015
    new orleans, la
    16
    Yes.
    I'm pretty sure that a 2007 system would not have the 02 11 0A 10 software. However, if that's what your system is showing, then I'm not sure why it's not working. If you're getting good flow, it should be working. Maybe a call to Jandy/Zodiac would be helpful.
    Support the site
  20. Back To Top    #20
    May 2015
    new orleans, la
    16
    Rechecked and it is 02 11 0A 10. 3 months ago I changed out sensor and I've been running program A for about 3 months and have not had problem. No Flow issue didn't show up until a week ago when i changed out the cell. when system initially powers up, flow. it is sometime later in the day that "no flow" lights up. Talked to Jandy and they suggested to reinstall the sensor from step one. They thought that maybe some gunk got on sensor in the process of installing the new cell. Went through installing sensor from step one exactly as instructions described. So far, 24 hours in, and have not had issues.
