Thread: Taylor OTO chlorine testing
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hey folks,
    So since I now switched to DPD-FOS testing, I have a good amount of OTO re-agents still left. So, im sure this has already been discussed, but I couldn't find it by searching, so I will ask again.
    I know the OTO testing considered obsolete, but is it still considered accurate enough to use on the daily basis, when pool has no issues and you're just maintaining your chlorine at the under 5ppm level? I'd rather save my FOS-DPD re-agents for when I really need to use them and still use the OTO testing for quick daily checks.
    What say you?
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Taylor OTO chlorine testing
    Yes, you can use the OTO for daily testing if you have FC goal of 5. Run the other test maybe once a week or if your FCappears to be higher than 5 on the color.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I use the OTO more than the FAS-DPD. It so happens that I don't like to let my FC dip below 5. I know what the usual appetite of my pool is, so if the color is darker than the highest color, I just dump the usual in and forget about it. Once a week or so I do the FAS-DPD test just to ensure things haven't gone sideways.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Terrific! Exactly the answers I was hoping for. Thank you!
    30,401
    I'll add one more answer. The OTO test is best used for the PRESENCE of chlorine. With time, like Richard320, the shading becomes apparent but it takes a while. Meanwhile it is VERY dependable and can assure you that chlorine is in your pool.
    Use the FAS/DPD test for precision. You can't do a SLAM without it. You cannot do an OCLT without it. Anytime you need to read High FC levels or precise FC levels, use the FAS/DPD
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Perfect!
