Results 1 to 7 of 7
Thread: Help finding a replacement pump
    May 2015
    Las Vegas NV
    2
    Want to replace my Hayward RS2000 pump, with a variable speed. Where do I start with researching things? Flow rates, HP.
    Anyone have any suggestions? New to the whole pool ownership thing, and Thank! everyone for their knowledge.
    This site has been a great help!
    Thad
    Las Vegas
    Approx. 20'x32' and 25,000 gallons
    IG Plaster finish, spa, water feature.
    Cartridge filter, rs2000 2hp 1.25sp main and 1.5hp waterfall pump
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Help finding a replacement pump
    This is my new favorite VS pump
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    38,235
    That Superflo might be a little weak for the spa / water feature in this case.
    You either need to look at the larger VS pumps, or just look for a comparable 2-speed to what you have, even just putting a 2-speed motor on your existing pump.
    DFW, TX
    24,450
    Yep, did not notice the spa. Definitely not big enough. Sorry.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Welcome!
    First, I must say I was expecting to see somewhere in Michigan listed as your location when i saw the screen name. Are you a transplant?
    I'd work backwards from your existing pump. Find the frame size of your motor and then hunt for a 2 hp variable speed the same size. It'll be a straight bolt in, no plumbing required. Don't ask me what to do about rewiring things - you've exhausted my store of knowledge about VS pumps.
    May 2015
    Las Vegas NV
    2
    Yes a transplant!! but loving the great pool weather. I have been doing a lot of reading and it just makes my head spin. In your opinion (a 2HP) would there be enough room to add solar heat on a single story home.
    Las Vegas
    TF-100 test kit
    38,235
    My smaller pump with a 1HP motor runs a large solar panel array.
    Your bigger pump (it is the Leslie's equivalent (Hayward RS are only sold by them) of a Super II I think) with a 2HP motor will be more than enough.
