Results 1 to 7 of 7
Thread: 100% short cycle vs 50% long cycle
    Jul 2012
    Austin, TX
    75
    Hi all,
    I am new to SWG. I will install a timer just for the SWG. Just wonder if I should run the SWG at 100% in a short cycle or at 50% in a long cycle. These are my considerations:
    1. pool chlorine fluctuation. short cycle = higher fluctuation. Is it harder too keep the pool clean?
    2. Cell life longevity
    3. energy efficiency. The control box runs pretty hot. I don't know if running at 50% or lower may be energy efficiency like a VS pump.
    Scott
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    38,274
    Re: 100% short cycle vs 50% long cycle
    1. Should not matter much ... could run in 2 short periods spread over the day.
    2. Does not matter at all ... life should be related to the generation time which is the same either way.
    3. It is either on or off ... uses the same amount of power when generating.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    The pump is the energy hog. Find out how little you can run it and then figure out how long the SWG needs to run to maintain FC with that many hours of flow. You might be surprised at how little you actually have to run the pump to keep the water mixed and the surface skimmed. It could well end up that you need to run the SWG 80 or 90% to match the pump flow.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Ditto. I'm running my pump 6 hrs a day and varying my swg output depending on conditions outside; temperature, cloudiness, pool use. I'm running the swg 80-85% currently.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jul 2012
    Austin, TX
    75
    I run my pump at 1450 RPM from 6:30 AM to mid-night. To complete one full turnover at the RPM, it takes 24 hours. With SWG matched to the current pump schedule, 55% is still too strong.
    Richard320's Avatar
    Jan 2010
    18,988
    Quote Originally Posted by scott_home View Post
    I feel extravagant when I ruin my pump more than 4 hours in a day!
    Forget turnovers and go by appearance. Check the link I posted in my last reply.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Before I got my new swg installed I was only running my pump about 2 hours a day just to save money. Pool still looked beautiful. Like Richard said, don't worry about turnover. Go by appearance. If I had/when I eventually get a 2 speed pump, I would run it more just because I like the way it looks when the pump is running.
