Thread: Looking for a low cost gas heater for a 5,000 gallon pool
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I tried to enable the heater a few days ago. BIG mistake!! Now I know where my metal came from. Could actually hear it rushing trough the piping towards the returns. Before I could get the valves rotated back, there were clouds of metal flakes spewing from the returns. Took me hours to vacuum it all up. Good thing I had placed a sock on the skimmer basket. Caught almost a pound of stuff.
    So now I want to find a low cost replacement. At least that's what I figure I'm going to have to do.
    Any thoughts.
    I know, I know. Need pics!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Looking for a low cost gas heater for a 5,000 gallon pool
    It might be possible to replace just the heat exchanger if that is of interest. Sometimes it is worth it if the rest of the heater is in good condition.
    Mark
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Exchanger costs more than brand new heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Forget the heat exchanger replacement. Not worth is because unless the unit is 4 years or younger, most likely the inside is in just as bad shape.
    Look at the Raypak's. A good unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
