Results 1 to 8 of 8
Thread: Hayward DE-6000 Clamp Assembly
    Jul 2014
    Westport, CT
    65
    Hi all. First time opening the pool myself, and am having difficulty putting the clamp assembly back on to my DE filter.
    I have a Hayward DE-6000 unit. The O-ring looks just fine, I have it lubricated, but the top half of the DE filter cover doesn't sit completely flush when the o-ring is in place.
    It's kind of lopsided, so that I can get one side down, but this causes the other side of the cover to be raised a little bit.
    As such, when I attempt to connect the clamp assembly, I can't even get it to close enough so that I can start to replace the brass nut. I've read the posts about tapping it with a rubber mallet, etc, but nothing seems to help. The side of the cover that is sitting over the o-ring is just fine, but the other side can't be tamped down.
    The "pool guy" who opened my pool last season replaced the O-ring so I assume its the correct part. It's pretty thick, but i'm not sure if this is normal course.
    Should the DE filter cover just sit easily on top of the O-ring or is my situation not unique, and the hard part is indeed, trying to get the clamp back on despite the lopsided cover.
    Thank you all.
    Looking forward to my first soup-to-nuts year of the BBB method.
    48,000 IG Gunite - Pool built 1999
    Hayward DE-6000 Filter w/ C-1100-SEP Separation Tank
    Hayward Super Pump 2.0-HP : SP1615Z1MEG
    Hayward H-Series heater
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Hayward DE-6000 Clamp Assembly
    I have that same problem.
    Fortunately, as a mechanic, I have a large assortment of pliers to choose from. Get a helper and two sets of channel locks or some big vise grips. Get one side started and clamp it with pliers, then go opposite and put some squeeze on it. It doesn't have to bottom out, just fit over the lower half. Then you put the clamp on. Since it's tapered, tightening it will force the two halves together. I have some comically large channel locks that I use to cinch the ends together enough to get the spring and nut on. If you don't, have your helper hold them together while you go around tapping the clamp with a rubber mallet. Once you can start the nut, it should go easier. Tighten the nut a bit, then tap the clamp with the mallet all the way around. Tighten some more. Just keep going until the nut runs out of threads. I usuaully run it a few minutes to leak check it and then shut it off and doublecheck the clamp nut.
    Jul 2014
    Westport, CT
    65
    Thank you again Richard. Glad to hear that its not just me, and it saves me the trouble of ordering another o-ring just to be sure its not the problem.
    Will try the channel locks now, but the vice grips sound like they'll come in handy eventually. I'm thinking you mean something like this : 11 in. Swivel Pad Locking Pliers
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    19,074
    Those'll work. I just use plain ones. They don't need to be clamped on too tight, just have the helper hold them if possible. You're not trying to get the one side set all the way, just keeping it from popping off while you fight the other side.
    Jul 2014
    Westport, CT
    65
    Thanks Richard. Followed your instructions and was able to get it on... Just need to get my pump reconnected now... Of course there's another issue.
    Seems like the pump grew about 1.5 inches longer since last year!
    Here's the one from last year with everything fitted nicely.
    Upon reattaching this year, seems like the connection to the DE filter is about 1.5 inches short.
    I wondered if this is usual and I'm supposed to replumb everything every year because PVC expands or something... Else,.. do I just force the thing to bend over 1.5" without snapping.
    Everything else is the same and unmoved from its location last year.... I'm at a loss on why the equipment has moved even a little bit...
    TF-100 Test Kit
    Most likely, the filter got moved out of place while you were working on the band clamp. You should be able to shift it enough to make the union align.
    Support the site
    Jul 2014
    Westport, CT
    65
    Thanks @JamesW. That's absolutely right. n00b...
    It also helped to loosely join up all the unions a bit at a time. e.g. I joined one return line, then the line from filter, then another return, etc.
    TF-100 Test Kit
    Support the site
