Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Baquacil to Chlorine Conversion - Questions
    Jun 2015
    Dayton/VA
    34
    Hello Everyone,
    Totally new here but I am tired of using Baquacil or I have a knock off called "Pool Elegance". Ready to move to chlorine. We have a 24,000 gallon in ground and wanted to make sure I follow the same process. I am waiting until my current test kits shows I have 0 biguanide and then I am going to start the process. Just a little nervous since we are at the beginning of the swimming season and just didn't was to loose too much time swimming my kids would hurt me. Just tired of hearing the "add more shock" to clear everything up. We have had the pool for 4 seasons. Year 1 great no issues at all, year 2 started getting mold, year 3 things were bad, and this year I just can't get the pool clear. Ready to take over my pool and not have to worry with everything. I know it can be work but just doesn't need to be this much work.
    Thanks for all the help in advance.
    Jeff
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Baquacil to Chlorine Conversion - Questions
    Welcome to TFP!
    Unfortunately your experiences seem pretty typical of the baqua crowd. Leebo, an admin here, is a great source of experience on this subject so hopefully he will chime in.
    We have a great process to make for a speedy switch, it can be found here: Pool School - Convert Your Baqua Pool to Chlorine
    Do you have one of the recommended test kits ordered? The TF-100 with the XL option (link in my sig) is the best choice for a baqua conversion as you will be adding a lot of chlorine and testing often. We also love to see pictures of these conversions, the colors are so pretty!
    If you choose to follow the methods taught here you will find that after the initial work of the conversion your pool care will in fact be quite easy. Similar to brushing your teeth, a little work daily will prevent a lot of hassle later. I hope you will read through some of the pool school (link also in my sig) and get a feel for what the site and TFPC is all about. Good luck with your conversion!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,627
    You are going to LOVE the TFP way! It will save you SO much money and time!
    You will not believe how clear your water will be!
    You will be able to tell if a quarter is heads or tails in the deep end!
    Kim
    Aug 2010
    Pinckney, MI
    30
    You will be SO glad you made the switch! I had a Baquacil pool for 15 years and just finished converting it to chlorine this past weekend. Everyone on TFP was SO helpful with encouragement and with answering any questions I had. It got rather discouraging in the middle of the conversion process, but my pool now looks prettier, clearer, and more sparkly than it ever has since it was new 15 years ago, and I'm kicking myself for not making the switch sooner. You won't regret it!
    P.S. Stock up on LOTS of bleach or liquid chlorine - you'll go through an amazingly large quantity of it!
    28,000 gallon Doughboy AG vinyl pool (21' x 40' w/7 ft deep end), installed in 1999
    Hayward Super Pump (2 HP, 1 speed), Hayward Star Clear Plus Filter (120 sq. ft.)
    Aquabot Turbo and Aquabot Turbo T-jet cleaners, Saltron Retro XL SWG
    Well water, Taylor TF-100 Test Kit
    Jun 2015
    Dayton/VA
    34
    Thanks everyone for the post. I have not gotten the test kit yet but going to place it on order. I will post lots of pictures. Should be starting in about 3 weeks. Want to get it all ready for the July 4th weekend.
    mrsklement - how much bleach did you end up using?
    Jeff
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Welcome to TFP!
    Just as a quick warning, you may want to bump up your schedule if you want it done by the 4th. Baqua conversions can be wildly unpredictable on how long it takes so you'll want to leave some extra room just in case. The sooner you can order your test kit (get refills too.......you'll use ALOT of reagent) and the sooner you can start the better.
    I'm still looking for info concerning "Pool Elegance" and the MSDS. It sounds just like Baquacil, but I want to find the MSDS before giving you the definite "thumbs up."
    Jun 2015
    Dayton/VA
    34
    Attached are the pictures of the product. If you need anything else let me know.
    Aug 2010
    Pinckney, MI
    30
    I went through over 100 bottles of bleach, and my conversion took 3 weeks from start to finish. I think I used more bleach than most conversions do, though. Not sure why, but maybe because my pool had been on Baquacil for a LONG time (15 years). It was really discouraging by the second week when it still looked like a murky, brown cesspool, was a bottomless pit swallowing endless bottles of bleach, and there seemed to be no end in sight, but it was worth it in the long run, because it looks beautiful and sparkly now. Don't get discouraged and give up!
    Jun 2015
    Dayton/VA
    34
    Everyone just tested my water this evening and my bacq levels were at 54. Should I wait to move forward or just plow on through? Shock was low at 18. PH 7.4.
    Jul 2012
    Tallahassee, FL
    30,627
    When you start is up to you BUT it is going to take a while. If you really want it done by July 4..................
    Kim
    Jun 2015
    Dayton/VA
    34
    Everyone....I have started the process and I will have pictures to post tomorrow......
    Jul 2012
    Tallahassee, FL
    30,627
    Looking forward to seeing how yucky it gets! I think it is a good idea to go ahead and start it. I hope it does not take long but you never know. Better do it now and not need the whole time than............not be done in time for the party!
    Kim
    Jun 2015
    Dayton/VA
    34
    Here is the start......about 7 pm last night.
    Donldson's Avatar
    NW Ohio
    2,917
    Glad to see you started now, you should be able to be up and running in time to celebrate your independence from baqua! Hehe, couldn't resist.
    Jun 2015
    Dayton/VA
    34
    Yeah no kidding....we are getting there....here is the most recent picture.
    Jul 2012
    Tallahassee, FL
    30,627
    Ewwwwwwww the conversion yuck! LOL
    Kim
    Jun 2015
    Dayton/VA
    34
    Everyone.....48 hours into the conversion and here are my levels....
    FC - 26.5
    CC - 9
    TC - 35.5
    PH 7.8
    Anything I need to change or just let things keep going as they are?
    Jeff
    Jun 2015
    Dayton/VA
    34
    Here are my results this morning about 60 hours in.
    FC - 18
    CC - 9
    TC - 27
    PH - 7.6
    Pool is starting to clear. Able to see the bottom in the shallow. Still cloudy but things seem to be turning the corner.
    Jul 2012
    Tallahassee, FL
    30,627
    Good job! Keep it up and you will have a REAL TFP!
    Kim
  20. Back To Top    #20
    Jun 2015
    Dayton/VA
    34
    New numbers for the day 80 hours in....
    FC - 13
    CC - 8
    TC - 21
    PH - 7.4
    Pool is clearing up will post pictures here in just a little have to put them on other site. Added liquid bleach this morning to get me back to FC of 15. Hope by Sunday we might be over the top.
    Jeff
