Results 1 to 14 of 14
Thread: New Pump Help Please
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    Hello,
    I have a Pentair Optiflo 347986 1.5 HP single speed that I need to replace. I have read that a 2 speed (less HP) would be better and more energy efficient than the single speed 1.5 HP I currently have for my 24 ft 52" round above ground.
    I see the Optiflo 347990 1 HP 2 speed on Amazon and thought it might be a good replacement. My question is - do I need to consider my filter (cartridge / DE) system also in making this selection? For example, is it possible that my filter requires a constant 1.5 HP to filter properly or will it run fine while using the lower speed on the 1 HP replacement?
    Thanks in advance for your responses.
    george
    38,301
    Re: New Pump Help Please
    Welcome to TFP!!!
    Filtration actually works better at lower flow rates. For a sand or DE filter, you need a decent flow for backwashing, but the 1HP on high will be fine.
    One note, you may be able to just replace the motor on your existing pump with a 2-speed version for less money ... assuming that the motor is the problem.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The OptiFlo is a good efficient pump. The 1.5 HP is actually about the same size as my 1/2 HP IG pump so you can't really judge a pump by it's label HP. You could just replace the current motor with a two speed motor.
    Mark
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    The problem is actually my bearings....the pump is only 5 years old and I had to have the bearings replaced last year for $90. Worked fine for the summer and when I plugged it in yesterday - bearings shot again....The pool placed that replaced them blamed it on cheap foreign made bearings in the pumps these days...I have no idea whether that's true or not. That's why I'm considering replacing it with something that will work as good but use less electricity...This article is the one I read.
    http://swimming.about.com/od/pooland..._pump_size.htm
    38,301
    Oh, then the pump should be fine ... just get a 2-speed motor and a new shaft seal.
    Did you replace the shaft seal when you have the motor fixed the last time?
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    All I know is they replaced the bearings....are you suggesting that I repair this myself by ordering certain parts? I wouldn't even know where to get a two speed motor for this model and shaft seal...what about the bad bearings?
    38,301
    The bearings are in the motor ... get a new 2-speed motor and slap it on with a new shaft seal
    I am pretty bad at finding the correct motors, but Mark can probably quickly tell you what would be a comparable replacement.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The bearings are in the motor so when you replace the motor, you are getting new bearings. It isn't too difficult to replace if you are handy. However, given a new pump is only a little more than a new motor and seal, you might be better off going with a new pump:
    Amazon.com : Pentair 340071 OptiFlo Horizontal Discharge Two Speed Motor Aboveground Pool Pump, 1 HP : Swimming Pool Water Pumps : Patio, Lawn Garden
    Mark
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    So I found this site for a replacement 2 speed motor....http://www.inyopools.com/Products/03...000408.htm#faq
    Any other thoughts or suggestions?
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is a single speed motor. A new two speed pump is not much more.
    Mark
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    Right, but I was mainly referring to the website.....do you have any thoughts Mark on this site and the quality of their motor replacements? Or do you recommend something else? Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have no opinion on sites but as I pointed out in a previous post, the cost of a replacement two speed motor and seal would be close to a new pump:
    Quote Originally Posted by mas985 View Post
    So why not get a brand new pump?
    Mark
    gfurman's Avatar
    Jun 2015
    Pittsburgh
    10
    Well, the motor replacement looks like it's $174 http://www.inyopools.com/Products/03000017000408.htm (this is the single speed) and the pump replacement on Amazon is $281....http://www.amazon.com/Pentair-347990...=ATVPDKIKX0DER.
    I'm not sure how much the seal kit is....but I'll probably do what you said.
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    So are you thinking of a single speed now? Because a two speed motor is more than a single speed:
    Waterway Motor, Thrubolt, 56fr, 2 Hp 230v, 2sp (b233, B2233, 372082113) - INYOPools.com
    With a seal kit, it will be about the same as a new two speed pump. It is up to you of course but you will make back the $100 difference (over a single speed motor) in less than 12 months of operation with the two speed and then save more than the single speed after that.
    Mark
