Thread: Why don't they make chlorine tabs with no CYA ?
    May 2013
    Long Island NY
    419
    Never thought about it much or researched it. Is there such a thing as chlorine only 3" tabs? If not, why not? Seems like something that would make life a little easier.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    38,251
    Re: Why don't they make chlorine tabs with no CYA ?
    Well, there are a lot of threads that discuss this exact question .... try the search
    Simply, it would violate the laws of chemistry.
    May 2013
    Long Island NY
    419
    Yep. Just checked. Chem geek explains it well. Thanks
    Jun 2014
    Oslo
    120
    DMH???
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    Mar 2007
    San Rafael, CA USA
    12,082
    There is DCDMH which is like bromine tabs except with chlorine only (bromine tabs are normally BCDMH with one bromine and one chlorine or sometimes DBDMH with two bromine). However, this is not generally available and it would build up DMH in the water. DMH may not behave quite like CYA but it will build up and at some point may affect disinfection/oxidation rates. We don't have info on the detailed equilibrium constants for it so don't know when it becomes a problem nor how much is needed to protect chlorine breakdown from sunlight or if it does that well. Too many unknowns to recommend it.
